Rear end dances over bumps
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Rear end dances over bumps in Past Cadillac Vehicle Discussion; Hey guys, the rear of my 98 DeVille dances around over bumps. I know the shocks need to be replaced ...
    John Boelte is offline Cadillac Owners Member
    Automobile(s): 1998 DeVille
    Aug 2012
    10
    Hey guys, the rear of my 98 DeVille dances around over bumps. I know the shocks need to be replaced and probably all of the ball joints and tie rod ends. Is there more I should look at replacing? I don't like the idea of replacing the A-Arm pivot bushings, but I think that might be the culprit. Any advice?
    Thanks,
    John
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Rear end dances over bumps
    the shocks dampen (or absorb) the oscillation of the springs ... if you are getting more than 3-4 oscillations then your shocks are worn
    other parts replace upon visual inspection
    Aug 2012
    10
    Im certain the shocks need to be replaced, I think it's more that something in the alignment changes. The rear of the car seems to go to the left.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    there are too many maybe's - and could be's -
    the ONLY way to be sure - get the car up on a hoist -
    and have the rear end carefully inspected -
    68
    82,064
    Control arm bushings.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    ^^^ That. Look on BOTH ends of the control arm. Keep in mind that he cross axis ball joints in the knuckle where the control arms attach are a problem area on these k-bodies. There are probably lots of threads on this if you find that these are your problem.
    Aug 2012
    10
    I think it's probably the A arm bushings and ball joints (and shock absorbers) causing my problems. I was hoping to get some definitive experience here before I dump a trunk full of money into the car. It's a big trunk, right?
  10. Remove Advertisements
