HELP! erratic idle
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, HELP! erratic idle in Past Cadillac Vehicle Discussion; Hi guys, I am a bit new to the Cadillac world so please bare with me. I have a 2001 ...
    63chevy is offline Cadillac Owners Member
    Aug 2012
    8
    HELP! erratic idle
    Hi guys,
    I am a bit new to the Cadillac world so please bare with me. I have a 2001 DeVille with a very erratic idle which is only getting worse with every attempt to fix the problem:
    The car runs erratic throughout the RPM range with idle speed being significantly worse.
    codes:
    O2 sensor
    cam position sensor
    torque converter
    TCC (transmission control computer) stuck off
    missfire bank 1
    In addition a loud hum and, in my opinion, an excessive amount of heat are coming from the right rear of the trunk (?thinking fuel pump?); also the micro relays under the rear seat are excessively hot.
    Probably unrelated, the car has suddenly begun to pull to the right with a noticeable vibration from the right front wheel.
    I have replaced the cam position sensor and the fuel filter.
    My thoughts are that having replaced the cam sensor with no positive effect the erratic idle is caused by a fuel issue, thus replacement of the cheapest component- fuel filter. Now it seems to run worse. With the cost of a fuel pump about $300 I'm looking for help before my wallet dies. Thanks for any input guys.
    68
    81,917
    Re: HELP! erratic idle
    When was the last time you cleaned the TB?
    Aug 2012
    8
    Probably 2002/2003. In fact I had thought about that the other day, and I guess promptly forgot about it; but I'll do that right now. On my other vehicles I clean them when I have another reason to take them off. Can i clean it while it's on the engine? Is there a prescribed method of cleaning? Thanks for the reply and the welcome.
    68
    81,917
    No need to remove it. Just block the throttle plate open, then...... well, you know what to do. I think there is a tutorial in the Tech Tips section if you need it.
    I assume you do not have a P0171 & P0174 code?
    Aug 2012
    8
    HEY! I have both. haha. And then some:
    PCM: P0171, P0174, P0300, P0340, P0420, P0741
    I have looked them all up, and am trying to make sense of them all.
    bank 1 lean, bank 2 lean, misfire, cam sensor, cat system, TCC stuck off, respectively.
    With the 171 & 174 codes and the heat in the trunk the evidince is mounting for a new fuel pump. As for the 0741, the transmission shifts fine. So, I wonder if that's an errant code or of those trivial codes that sound important.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    Quote Originally Posted by 63chevy View Post
    you have a torn plenum - resulting in a huge vacuum leak -
    the plenum is the bellows-looking piece
    between the throttle body and the intake -
    with the engine running - spray carb cleaner in that area -
    if the idle speed increases - you found the leak -
    you might be able to feel it with your finger -
    the split is always on the bottom -
    there is a "HOW-TO" replace it in the "TECH-TIPS" forum -
    68
    81,917
    Yup, the plenum is your problem.
    Aug 2012
    8
    Thanks for all the help guys. I could hear the air being sucked in, but I never would have found the tear without removing the plenum. It was right up against the flange from about 5 o'clock to 7 o'clock. once I gave up my great desire to not dismantle the intake system it was really pretty easy.
    The one problem I had was when I spayed the brake clean it was sucked into the combustion chamber and out came a very toxic cloud that permeated everything, and sent me out of the garage for some time. It's only too bad I didn't need to replace the starter, as I'm sure it will go out soon now that I have done all that work. Haha. Thanks again for all the help.
    68
    81,917
    You'd be surprised at just how long these starters last being tucked away high, dry and relatively cool (compared to being tucked under the exhaust manifold).
  12. Remove Advertisements
