4.6 Valve cover seepage
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 4.6 Valve cover seepage in Past Cadillac Vehicle Discussion; I noticed there is some seepage around parts of both the valve covers on my 05 deville. I have lost ...
    oldmanlesabre is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville
    Mar 2012
    26
    139
    I noticed there is some seepage around parts of both the valve covers on my 05 deville. I have lost some oil over about 4000 miles, but it went from the middle of the hashmarks to maybe 1/6th of the way up the hashmarks on the dipstick. Just wondering if that is 'normal' At almost 98,000 miles now. Guessing I should plan on replacing them just because, then again, I have heard GM claims seepage is normal on some engines? Thoughts anyone?
    68
    82,083
    Re: 4.6 Valve cover seepage
    Some oil consumption is normal. Leaking or seepage is not. Usage varies. Pre-2000's seemed to use more than the post 2000's. I would think a qt per 3000-4000 miles would be about what would be expected from yours.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,276
    FWIW, 95% of other Northstar drivers would kill to get that sort of "oil mileage". If it ain't broke don't fix it...........
    ......... almost ALL of your observed oil use was from normal oil "burning", not valve cover weeps - a little oil on an engine goes a LONG way toward making things greasy and dirty.
    Mar 2012
    26
    139
    hmm. well thanks for the feedback, good points definitely. I guess I will just clean it up and see how much it weeps out over time for my own curiosity, a little bit of oil can look like quite a mess!
    Feb 2006
    56,276
    Be very careful how you "clean it up" - These engines DO NOT like to get overly wet or power washed............. You are warned.
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    64
    347
    I had horrible oil leak on my '03 (with 55k miles) when I bought it last Fall. I could smell the burning oil while driving, so I had to fix it. After putting up on lift, we determined that the main culprit was rear valve cover gasket. I replaced that gasket myself (not a job for a novice) and that fixed almost all of the leak. I still get a small drip on garage floor at night, likely from front valve cover gasket - which I will do when I next feel totally bored, LOL.....
    Mar 2012
    26
    139
    Ordered the fel-pro set...no oil loss....then all the sudden I get check oil alarm when i start up....Strange! shut off, wait for a minute check level, its low, but I figured I would let it settle for a few more minutes, and I ended up adding my first quart...sad thing is I have not been adding much oil at all... So I checked behind balancer...glanced underneath...nothing irregular, nothing anywhere, then look at valve cover in the rear, and hmmmm looks to have seeped a fair amount more, must have just noticed it right when it started... topped off oil, drove around, went in store, came back, checked level checked for puddle. good level, no puddle, gotta be the culprit. Changed sparkplugs 99.5k, (some lazy idiot put some autolites in the two outside rears and the 4 in front, and the two originals were behind that deal for AIR system, another lesson learned, knew I should have changed them out when I bought it!) out...and found a tiny bit of oil on the 3 rear driver side plugs- on the threads only, not the end or up where the boot was...not much at all but enough to make it apparent what the problem is.
    Feb 2006
    56,276
    ANY Northstar will seep a bit of engine oil into the spark plug wells - it's an artifact of the cam cover O-ring seals. Not uncommon, not to worry.
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,758
    Quote Originally Posted by oldmanlesabre View Post
    Think of that oil as rust/corrosion proofing
  12. Remove Advertisements
