Replaced fuel pump now inside of the car has a gas smell
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Replaced fuel pump now inside of the car has a gas smell in Past Cadillac Vehicle Discussion; I had my fuel pump and fuel filter replaced in late May in my 2000 Deville. Now I often smell ...
    tutball is offline Cadillac Owners Member
    Automobile(s): 1996 AND 2000 CADILLAC DEVILLE
    Nov 2010
    33
    33
    I had my fuel pump and fuel filter replaced in late May in my 2000 Deville. Now I often smell gas when Im driving. It is also stronger when I fill my car up. Now I know my fuel pump is located in my trunk under the matting. I have subwoofers in the trunk but the gas smell has never been a problem until I got my fuel pump replaced. Is it possible that something came lose or that they put the wrong fuel pump in? I have the manual and illustrations for the deville is this something I possibly could fixed because the shop that replaced the fuel pump is over 500 miles away. Thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,231
    Re: Replaced fuel pump now inside of the car has a gas smell
    It's either a leaking fuel pump module lock/seal ring, fuel line connectors, EVAP canister/solenoid or rusted fuel filler pipe.
    The fuel pump module is in the fuel tank. The access hatch (in your car) is under the trunk carpet.
    Nov 2010
    33
    33
    Update I filled up at the gas station and went in to grab a drink I come back out and notice gas was leaking from under my car. Also check engine light popped on about a week after getting my fuel pump and filter replaced. So I went to auto zone and got a diagnostics test and it revealed loose gas cap. So I tighten the cap that was already tight and the light stayed on. Any suggestions anyone?
    Feb 2006
    56,231
    Ummm, Post #2 ???
    Feb 2003
    california
    69
    6,663
    Re read post number 2!!! The Auto Zone test showed a code for fuel evap. system. Not a loose cap. When the tank wont hold pressure, a check eng. light comes on. I cannt believe you havent pulled the inspection cover off and looked for stains of fuel around the fuel pump module lock ring. When you ask for help we assume you can at least check what we advise to check. If you want free diagnosis, eyes are better than the written word.
    Nov 2010
    33
    33
    Update #3. I jacked up my car to see if I could identify where the leak was coming from and seen nothing out of the obvious. So I lowered my car back down and heard fluid leaking onto the pavement. So I crawled in my trunk and open up my fuel pump compartment and saw gas residue. I pumped it back up with the lid off and seen the compartment start to fill with fluid. When I lowered it again the fuel drained. I dont believe this is normal. I just had the fuel pump replaced. Any suggestions?
    Nov 2010
    33
    33
    Update #4. Thanks for all your help I will replace the fuel pump o -ring in the morning and that should solve my problem if not??? Thanks
    68
    82,068
    Quote Originally Posted by tutball View Post
    No it is not normal. Take it back to whoever did the replacement and let them fix THEIR mistake.
    Nov 2010
    33
    33
    Thanks. I would do that but I would have to drive 500 + miles to do so.
    Nov 2010
    33
    33
    Im researching o-rings tonight. Is it even possible to buy just the o-ring for the Airtex fuel pump model e3518m? Im having a hard time finding just the o-ring.
    68
    82,068
  14. Remove Advertisements
