A/C condensation causing wet floor
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Submariner409
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, A/C condensation causing wet floor in Past Cadillac Vehicle Discussion; I went to vacuum out my car this morning and noticed my floor was wet and starting to mold under ...
    tutball is offline Cadillac Owners Member
    Automobile(s): 1996 AND 2000 CADILLAC DEVILLE
    Nov 2010
    33
    33
    I went to vacuum out my car this morning and noticed my floor was wet and starting to mold under the floor mat of the passenger side. I looked under my dash and noticed there was a lot of condensation building up under the dash. Also my back floor on the passenger side was also wet too. Could someone please help me identify the reason for this? Any help would be greatly appreciated. Thanks in advanced.
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Did not see car year, but I'm gonna take a stab at this and say AC drip houses plugged or heater core leaking.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,174
    Re: A/C condensation causing wet floor
    In either Deville, the A/C condensate drain fitting comes out of the lower firewall edge just about where the passenger's left heel would rest. Up on a lift, use a fuzzy pipe cleaner (craft shop) to clean the drain elbow out. Your car(s) should leave a right good sized puddle of water on the pavement at each stop light in this weather.......
    KheSanhVet likes this.
    69
    82,396
    It has to be the A/C drain, otherwise he'd be complaining of no heat, coolant smell, low coolant message and foggy windows. I'd almost bet that once he squeezes the elbow water will flow like a faucet.
    Nov 2010
    33
    33
    Thanks guys I will be to sure to do this Friday when I have the free time. I really appreciate your amazing feedback.
    69
    82,396
    Here's the drain that Sub mentioned. Part #21
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    57
    388
    my 03 did the exact same thing, i squeezed the elbow and it pee,d like an elephant
    cookt is offline Cadillac Owners Member
    Jul 2012
    23
    I had the issue with my 04 DTS. Thanks.
    Nov 2010
    33
    33
    Awesome advice. The drain plugged was clogged. I took some pics will post as soon as I get a chance. Thanks for the help.
    DonRSD's Avatar
    DonRSD is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Escalade ESV
    Aug 2009
    South Florida
    37
    185
    I have a little water on the rim of my spare tire in the trunk, any suggestions?
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Quote Originally Posted by DonRSD View Post
    Totally different area on the car. You need to start a new thread...
    swelson@me.com is offline Cadillac Owners Member
    Automobile(s): 2008 DTS
    Feb 2013
    3
    Tutball,
    I am having the Same issue.
    I have a 08 DTS and the front drivers and passengers side floor is just short of a pool of water.
    I had to remove the carpet up to the front seat in order to vacum and soak up the water.
    the padding is very thick and it is just like a sponge. carpet is hard to wring out.
    without ruining it.
    Did you resolve your issue.by unplugging the Condensate drain?
    or was it a larger issue...Please let me know.....Thanks
    Can you post a photo of the drain location?
    Please
    Thanks
    69
    82,396
    Can't find a diagram for yours, but it should be under the firewall on the right side. Look for a rubber goose neck.
  16. Remove Advertisements
