My 2001 DTS didn't start every time..... Please Help
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Like Tree2Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, My 2001 DTS didn't start every time..... Please Help in Past Cadillac Vehicle Discussion; HI EVERYONE , How are you This is my problem: starting failure like whats happened to a lot of cadillac ...
    RoOoGy is offline Cadillac Owners Member
    Automobile(s): Deville 2001 & 2003, DTS 2006
    Jul 2012
    25
    AngryMy 2001 DTS didn't start every time..... Please Help
    This is my problem:
    starting failure like whats happened to a lot of cadillac owners.
    the problem detail: everything working fine from the key to fuel pump to the dash panel and no DTC error but after all of this the car doesn't start.
    and the stupid solution we had to do it everyday is trying to start the engine so many times until starts.
    please help me.
    Regards, RoOoGy
    68
    81,746
    Re: My 2001 Cadillac DTS didn't start every time..... Please Help
    Start by checking your fuel pressure.
    Jul 2012
    25
    Fuel Pressure is fine. what else can I check
  5. #4
    68
    81,746
    Re: My 2001 DTS didn't start every time..... Please Help
    What is your fuel pressure?
    Might try cleaning the TB. Does it start easier if you crack the throttle open?
  6. #5
    Jul 2012
    25
    I did cleaning the TB and I tried to keep the throttle open when I start the engine and nothing happened.
    thanks for your help ( Ranger ).
    and the problem still happening.
  7. #6
    68
    81,746
    Once again, what is your fuel pressure? Gotta start with the basics. Otherwise we're just guessing.
  8. #7
    Jul 2012
    25
    i don't know what is my fuel pressure in detail. but the man who checked for me the fuel pressure he told me its perfect.
    if you can tell what can i do to test the fuel pressure by myself please tell me.
    thanks again for everything
    RoOoGy
  9. #8
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Rent a fuel pressure gauge, hook it up to the Schrader valve on the fuel rail, turn the key to the ON position.
  10. #9
    68
    81,746
    If you had the pressure checked and he used a fuel pressure gauge, I guess it should be fine then. The "stupid solution" you mentioned in post #1 led me to think low fuel pressure.
    How does it run after you get it started?
  11. #10
    Jul 2012
    25
    nothing wrong with the car after the engine start, everything is good from idle to performance to everything you ever imagined.
    thanks again
  12. #11
    Jul 2012
    25
    PostRe: My 2001 DTS didn't start every time..... Please Help
    Hi, Additional info: when I noticed the problem I thought its PASSKEY III issue but when I read about it and seeing this webpage http://www.pdqforensics.com/sec410010.html but i was wrong because the PASSKEY III its security starts with the key and ends with the fuel pump, and all of that working in my car.
    and I know someone who told me the problem maybe in the starter or the starter connection ( wires ).
    so I'm very confused so help me please.
    and my problem the same in this video:
  13. #12
    Jul 2012
    25
    ExclamationRe: My 2001 DTS didn't start every time..... Please Help
    PLEASE! Anyone can help me .
    Note: anyone want to help please read the whole thread because there is some additional info.
    thanks
  14. #13
    Sep 2010
    East Boston MA.
    29
    26,325
    Wait, so the problem is the engine doesn't CRANK?
    I think we were all under the impression that it was cranking and not starting.
    RoOoGy and RoOoGy like this.
  15. #14
    Jul 2012
    25
    Yes you right.
    even I don't hear any sound except the fuel pump
  16. #15
    Sep 2010
    East Boston MA.
    29
    26,325
    Ok, that changes things. Fuel pressure and cracking the throttle open are irrelevant. The problem is with the starting circuit. Does the starter relay click when you turn the key?
  17. Remove Advertisements
