Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 31
Thread: My 2001 DTS didn't start every time..... Please Help
  1. #16
    RoOoGy is offline Cadillac Owners Member
    Automobile(s): Deville 2001 & 2003, DTS 2006
    Jul 2012
    25
    Re: My 2001 DTS didn't start every time..... Please Help
    I'll check, and back with the answer later.
  2. #17
    Jul 2012
    25
    Ok, that changes things. Fuel pressure and cracking the throttle open are irrelevant. The problem is with the starting circuit. Does the starter relay click when you turn the key?
    OK, I checked about starter relay and yes its clicking.
    so what's the next step.
    thanks
  3. #18
    69
    82,278
    Check the battery voltage and the cables. Cables should be clean and tight.
  4. #19
    Jul 2012
    25
    Thumbs up Re: My 2001 DTS didn't start every time..... Please Help
    OK, the battery voltage is 12.5v before starting the engine.
    And the cables is very clean and tight because its new.
    Thanks
  5. #20
    69
    82,278
    OK, now what is the voltage when you try to crank? Do the headlights go REAL dim?
  6. #21
    Jul 2012
    25
    No everything is normal and the battery in very good condition ( I bought it 2 months ago )
    And the headlights go to NORMAL dimming.
    Thanks again
  7. #22
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    sounds like it has been narrowed down to
    either ignition switch -
    neutral safety switch -
    or a bad starter -
    if the neutral safety switch is going bad -
    or is slightly out of adjustment - this may work -
    put your foot on the brake and hold it -
    try putting the shifter in neutral and turn the key to start -
    if nothing - wiggle the shifter - between Drive and Reverse -
    while holding the key in the start position -
    if nothing - put it into park really hard -
    again wiggle the shifter -
    if the car starts at some point - you found the problem -
    if it doesn't start - you can NOT rule out the NSS
  8. #23
    69
    82,278
    Perhaps a loose battery cable on the starter solenoid?
  9. #24
    Jul 2012
    25
    Quote Originally Posted by basscatt View Post
    or a bad starter -
    I'll try your way and I'll tell about the result.
    thanks to your help.
    I'll check about what you said to me.
  10. #25
    Jul 2012
    25
    Hi, About what you said about neutral safety switch. this is what I did:
    hold taping on brake pedal - put the shifter in neutral - turn the key and i wiggle the shifter between drive and reverse, but here is my question:
    (Is that normal the shifter going to drive and reverse very smoothly while holding the key in starting position )
    Please answer my question
    Thanks
  11. #26
    69
    82,278
    I think he meant to wiggle it in park or neutral, but it should be able to move like you said as long as you foot is on the brake. That releases the shift interlock.
  12. #27
    Jul 2012
    25
    Hi, I've tried the solution about neutral safety switch and nothing happened and the problem still going.
    please help me.
  13. #28
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    Remove the rear seat, to gain access to the battery. Check all connections, positive and negative at the battery, the fuse box underneath the seat. There is also a ground conection underneath the seat, make sure that is clean and tight.
    Disconnect, the positive lead AT THE BATTERY. Open the hood, go the fuse box on the right side of the vehicle. Remove the main fuse box cover, the one with the red positive cover attached to it. Make sure the leads from the starter that attach to that fuse box are clean and tight.
    Next to the fuse box, looking down towards the frame rail, in between the fender and the fuse box is a ground strap stud, Make sure that ground cable is clean and secure there. That cable also attaches to the head. Getting to the connection at the head will be tricky, but it can be done, make sure that connection is tight also.
    Underaneath the vehicle, on the LEFT SIDE FRONT, at the transmission, there will be two or three small grounds that attach to the transmission, double check those.
    After checking all conections with the battery disconnected and you feel certain that they are clean and secure, reconnect the battery under the seat.
    Attempt to start the vehicle again, hope for the best. Otherwise, you'll be pulling a starter to test or replace.
  14. #29
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    I watched your video twice and you stated you started the car and drove to your friends house and came outside and it won't start.
    You either have a loose connection somewhere or the starter is failing due to something called age or what used to be known as "heat soak".
    Starters used to get some warm from being near exhaust that a lot of them had heat shields to protect the solenoid from the heat. Yet, where the starter is located on a northstar, it shouldn't be possible.
    Most likely a loose connection. Good luck.
  15. #30
    gbarb is offline Cadillac Owners Member
    Automobile(s): 2002 DTS
    Apr 2011
    Indiana
    40
    16
    RoOoGy......did you ever find out what was wrong? I'm having a similar issue. Please get back with me. Thanks!
  • You may not post replies
