2000 Deville traction light comes on when its night time
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 Deville traction light comes on when its night time in Past Cadillac Vehicle Discussion; its not a lie i have 2000 deville my traction light never comes in day time but it comes on ...
    imran is offline Cadillac Owners Member
    Automobile(s): pearl white deville 2000
    Jun 2012
    41
    8
    its not a lie i have 2000 deville my traction light never comes in day time but it comes on when its dark outside,i dont know why is that i took it to mechanic he replaced both front rotors,pads,,,tierod bushings right side wheel bearing,and sway bar bushings ,he said this will take care traction light,but it comes on again when its dark.its happening 5 days in a row now.and car has no codes at all,any good solution will be appreciated.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The ONLY part that your mechanic replaced, that could possibly trigger the message, is the bearing. How are you pulling your codes? With an external scanner, or through the DIC?
    Jun 2012
    41
    8
    Both ways,I went to autozone twice and a guy said no codes at all,and I did it myself through dic still no codes
  5. #4
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    46
    413
    Re: 2000 cadillac deville traction light comes on when its night time
    Sounds like a short in the circuit. At dark/night the only difference I can think of is the headlamps come on. Try turning on the headlamps with the switch during the day and see if the Traction Light comes on again.
    Vernon
  6. #5
    Sep 2010
    East Boston MA.
    29
    26,325
    NO codes? None in history? Exactly what light/message are you getting? Service TCS system? Traction engaged?
  7. #6
    Jun 2012
    41
    8
    Quote Originally Posted by MoistCabbage
    Traction controll,only the orange light nothing else
  8. #7
    Jun 2012
    41
    8
    Quote Originally Posted by Manic Mechanic
    Vernon
    Yup I tried drove like hour/half no light
  9. #8
    Jun 2012
    41
    8
    Theres another thing I forgot to mention, car shakes like if I go above 70,already did wheel balancing still no luck
  10. #9
    pjb95 is offline Cadillac Owners Member
    Jun 2012
    4
    My ABS traction control light on my 95' Deville is on consistently. It's been disabled maybe , easily 5 years now!! It also triggers the message on the dashboard " service engine soon" don't be alarm, it come and goes on my car! unless you are really concern about having your ABS brakes working to the manufacture standards! I consulted with the gm good wrench guys about this issue. It's $75 just to diagnose the issue. They told me directly, it's an overrated issue which isn't worth fixing! That's my opinion, my car runs great, has been running fantastic for years regardless of all those messages and sensors going off on my electronic dashboard!
  11. #10
    Sep 2010
    East Boston MA.
    29
    26,325
    If the orange light is on, there has to be at least 1 C (chassis) code stored. Are you sure you're pulling the codes correctly? Go back and re-read the sticky on how to do so.
    The Service Engine Soon light has NOTHING to do with a TCS/ABS fault. Ignoring it isn't doing you any favors, please don't suggest that other members do so.
  12. #11
    Jun 2012
    41
    8
    Thanks for your help finally I was able to get rid of shaking after alinement and balancing ,but still got the traction problem,and it's very strange it comes only in dark,I tried in day time to keep my lights on,but no light at all,as soon it's starting dark outside the orange traction light comes in display,I showed many mechanics and spent money but couldn't figured out,any help will appreciated.
  13. #12
    Sep 2011
    46
    413
    I want you to check something. I need you to check for proper operation of the Center High Mounted Stop Lamp (CHMSL), the reverse lamps, and the license plate illumination lamp. And I mean check it good. You will need a helper who is a competent driver with normal shoes on (don't want you or your house to get smashed because your 14 year old daughter got her flip flop stuck under the pedal etc.) Check all them in park, reverse, and drive with foot on and off the brake pedal, daylight and night. If at any time one or more cuts out or doesn't illuminate when it should be you should inspect the truck lid wiring harness in the immediate area of the trunk hinge for broken or shorted wiring. If it's just the CHMSL that isn't functioning also check it's resistance with an Ohm meter. Between hot and ground it should be 390 Ohms + or - 10.
    This happens a lot, and causes a traction control lamp along with codes. I know you say you have no codes but this is the only thing related that I can find for a phantom traction light on this car.
    Vernon
  14. #13
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    try covering up the photocell during the daytime to make the car think that it is night
    and see if the traction light comes on then
    if so then looking in the schematics for that photocell daylight signal could help track down the root cause
  15. #14
    Jun 2012
    41
    8
    finally figured out the light comes on when turn signal flashes with head lights,day or night,any idea whats going on
  16. #15
    twelcher is offline Cadillac Owners Member
    Nov 2012
    Quote Originally Posted by imran
    Did you get it fixed?
  17. Remove Advertisements
