Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Sirius XM?
    kjd03842 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DeVille DTS
    Feb 2005
    NH
    228
    Sirius XM?
    Is there a stock radio with Sirius XM that fits an 03 deville prperly? ie an original bose, or aftermarket model that will fit and look proper?
    (My wife has it in her new Ford Flex and I am hooked)
    Thanks
    KD in NH
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    Re: Sirius XM?
    yes - my '02 DHS has the BOSE radio with XM satellite -
    it looks exactly like the regular radios -
    the RPO code was:
    U2K -
    DIGITAL AUDIO SYSTEM S-BAND DIGITAL S-BAND AUDIO SYS -
    it was a somewhat rare option - only 709 '02 DHS models had it -
    the cars with it are fairly easy so spot -
    they have an extra shark-fin antenna on the roof -
    if you could find one - it would mount right up -
    you would also have to install the satellite antenna -
    then the dealer would have to program it to your VIN -
    elmysterio is offline Cadillac Owners Member
    Automobile(s): 2003 cadillac dts
    Apr 2012
    45
    Re: Sirius XM?
    my 2003 dts has it I have the delco bose stereo in mine with satilite radio radio.jpg
  5. #4
    Ian-STS99 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville Limited Edition
    Dec 2008
    225
    Re: Sirius XM?
    I got a Base Deville with the standard radio, it too has the stat radio, and I just got a 3 month trial on it.
    Works well until you go under a bridge or near tall buildings and then the signal is lost.
    I'm not sure if it's worth the $15.00 monthly fee, but I'll know more once the 3 month trial ends.
  6. #5
    Feb 2005
    NH
    228
    Re: Sirius XM?
    Quote Originally Posted by elmysterio View Post
    That looks like the same radio i already have....but i don't have any owners manuals. Maybe I just need to activate it?
  7. #6
    Apr 2012
    45
    Re: Sirius XM?
    click the band button and see if it says satillite radio
  8. #7
    Feb 2005
    NH
    228
    Re: Sirius XM?
    When I press the PTY button it says "No Satellite Radio"
  9. #8
    aeronca36606 is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Coupe Deville 4.1 V8 & 4.3 V6 Deisel & 1970 Eldorado
    Sep 2005
    East Tennessee
    773
  10. #9
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    Re: Sirius XM?
    [QUOTE=kjd03842;2994226]That looks like the same radio i already have....but i don't have any owners manuals. Maybe I just need to activate it?[/QUOTE--------------------
    look at the Regular Production Orde label on the underside of your spare tire cover -
    it lists all the options your car was built with when it left the factory -
    look for the code U2K - that is the RPO code for the BOSE satellite radio -
    if you find a UM5 RPO code - that is the regular BOSE NON sat radio -
    go here for a FREE owners manual for your '03 Deville -
    http://www.manualowl.com/am/Cadillac/2003-DeVille/Manual/216
  11. #10
    Feb 2005
    NH
    228
    Re: Sirius XM?
    Quote Originally Posted by basscatt View Post
    Confirmed, mine is non-satellite, thanks Basscat. I'll check out ebay for a sat version I guess.
  12. #11
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    Re: Sirius XM?
    Quote Originally Posted by kjd03842 View Post
    you need to understand a couple things before spending
    much time searching for a BOSE stock sat radio -
    they were NOT very common -
    it needs to be from a 2002 or newer - I think that's they changed it -
    the older radios use a different data bus - and simply won't work -
    if you do find the correct one -
    you also need the special SAT radio antenna -
    the SAT radio antenna needs to be installed on the roof -
    and the antenna cable wired under the headliner - and down to the radio -
    after all that is done - you must go to the dealer -
    to have the radio unlocked and "blessed" with your VIN number
    I have heard of dealers charging anywhere from $50 to $125 -
    to unlock the radio -
    if you get it all done and working - it will look stock -
    but that is a mighty big expense to go through -
    I would look into some other options if you are that
    sold on sat radio -
    I tried it occasionally during the initial free 6 mos period -
    never even considered paying for it -
    but I also have the 6 disc CD changer - that was enough -
  13. #12
    Feb 2005
    NH
    228
    Re: Sirius XM?
    thanks basscat, definitely things to consider.
    if I do go for it, definitely would want stock. Not big on after-market add-ons cluttering up the interior.
    Also noticed, when i pulled the spare tire cover, the trunk was wet underneath. Had that problem in my 98 Seville, a new trunk seal corrected it. Dried it out, will see if it recurs often enough to bother mitigating.
    Thanks again everyone for all the info.
  14. #13
    alfarop1999 is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Jan 2013
    27
    46
    Re: Sirius XM?
    Old thread but what if u dont have either U2K or UM5 rpo codes?
  15. #14
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    Re: Sirius XM?
    Quote Originally Posted by alfarop1999 View Post
    go here - and put in your VIN number -
    it will display all the equipment your car left the factory with -
    along with all the RPO codes -
    http://www.compnine.com/vid.php
  16. #15
    Tonyny's Avatar
    Tonyny is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Dec 2003
    Clermont, Florida
    63
    143
    Re: Sirius XM?
    Or you can install an aftermarket one like I did. DVD, CD, NAV, AM/FM, XM, etc
  • You may not post replies
