Results 1 to 7 of 7
Thread: 92 deville Running lights won't shut off?!!!
    Oct 2004
    9
    Cool 92 deville Running lights won't shut off?!!!
    Hey
    I have a 92 deville and notice last night that my running lights won't turn off .
    Has anyone had the problem and what is the fix ?
    Thanks
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    Re: 92 deville Running lights won't shut off?!!!
    maybe you have twilight sentinal on, and are not waiting long enough to watch them go out?
    twilight sentinal makes the lights go on and off automatcially at night.... but depending how far you turn the knob, they will stay on from 3sec to 3min.... to light your way while going into your house etc...
    Oct 2004
    9
    I wish that was the problem but the running lights are not shutting off. I waited almost a hour last night. I just pulled the fuse and this morning they are still staying on evening during the day . I will keep pulling they fuse until someone can help me figure it out.
    Please Help
    Thanks
  5. #4
    Jan 2004
    Amherst, NH
    29
    4,178
    Theres probably something wrong with the light sensor on your dashboard.
  6. #5
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Try pulling the manual headlight switch all the way out to turn on the headlights, then pushing it all the way back in.
  7. #6
    Oct 2004
    9
    Hey
    I have tried everything . Nothing seems to work .
    Thanks
  8. #7
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    On my 80 T/A I had some really odd things like that happen and it ended up being a diode shorted in the alternator.
    Basically it made a new path for power through the dash via the voltmeter (in your case, the alternator light). Look for it to be on, even dimly. That might be the case.
    It was the bridge rectifier in my case, I don't remember exactly which diode in the bridge was shorted.
    Remember also that GM likes to use switched grounds, so often if a wire gets shorted to ground, it does nothing more than turn something on. The dome lights are for sure. On my car the brake light fuse would blow on occasion and the dome light would be on with the headlights on, and then open the door, turn off. Headlights off and it would do other oddities.
    So check Alternator, check headlight switch, check for blown fuses, check for shorted lightbulbs and then see where you end up.
    Tom
  • You may not post replies
