What tool do I need for strut bolt?
Results 1 to 14 of 14
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, What tool do I need for strut bolt? in Past Cadillac Vehicle Discussion; Hello again forum, I have the strut off my 97 Deville and I have the spring compressed but I cant ...
    nekobarnes is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac Deville
    Apr 2009
    39
    65
    Hello again forum,
    I have the strut off my 97 Deville and I have the spring compressed but I cant figure out what tool I need to get the top strut mount off. What tool and what size? Any help would be appreciated!
    Thanx!!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Stock or after market struts?
    The tool required to hold the strut shaft still can really only be one of 3 things:
    External hex (like a regular bolt)
    Internal hex (Allen wrench)
    Torx ("star")
    Apr 2009
    39
    65
    Re: What tool do I need for strut bolt?
    I have the Arnott struts on the front, I see where I have the hex in the middle of the bolt, but I can't figure out what tool(s) are supposed to be used. Whenever I try to turn it with a regular socket the shaft will only spin. I can't use the allen wrench at the same time I use the socket.
    Sep 2010
    East Boston MA.
    29
    26,325
    Use the Allen (or Allen socket) to hold the shaft still, and a wrench on the nut.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    This can be pretty difficult without the correct hand tools. Sometimes, the nut is so far recessed in the strut mount that a normal open or boxed wrench won't fit on it.
    Although it ends up being very controversial, I recommend using an impact wrench.
    Sep 2003
    Metro ATL
    4,854
    Some strut top nuts require a tool "similar" to this. A deep socket with a flange and 3/8" drive hole. The proper torx or allen wrench goes through the center of the socket.
    Not too difficult to fabricate.
    Look on eBay / Motors / Tools / Kent Moore J-42468
    This is only an illustration; I have no idea if the socket is the correct size for the OP's car.
    Apr 2009
    39
    65
    Thanx guys, I just took it up to the local mechanic and he used an impact wrench on it, and he didn't even charge me.
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by nekobarnes View Post
    Whatever works. Now, how do you plan to torque the new strut top nut to the correct value?
    Apr 2009
    39
    65
    He torqued the big nut after he threw the new strut mounts on it. My problem is I sheared one of the tower bolts off when I torqued it so it looks like i'm gonna have to buy another strut mount and begin the process all over again. Oh and the ride is much harsher with 18" wheels in place of the stock 16 inchers. The car feels very stiff.....it's gonna take some getting use to.
    Oct 2004
    Oak Creek, WI
    5,609
    The torque on these components isn't so critical that you need to use a torque wrench - just look at the size of the nuts and use common sense. The large center nut needs to be threaded to the bottom of the threads on the strut shaft, plus a little extra to snug it up and help prevent it from backing off (it should be a nylon lock nut). Those smaller (13mm?) nuts on the mounts don't need much all. You should NOT be using your 1/2" socket wrench on those.
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by drewsdeville View Post
    That approach does not work very well on wheel lug nuts or head bolts or thousands of other places.
    Machinery builders could avoid spending a lot of time/effort ($$) by not even considering torque values for fasteners and paying technical writers to publish those values in Service Manuals.
    Who knows? Maybe the Space Shuttle program would still be funded if the engineers had not been so picky about spending the time/effort ($$) to establish fastener torque values.
    The large center nut needs to be threaded to the bottom of the threads on the strut shaft, plus a little extra to snug it up....
    Yikes.
    ....My problem is I sheared one of the tower bolts off when I torqued it....
    Have I said enough about fastener torque values??
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,936
    Here are the proper strut holding tools for a 2000 and later Seville. The shaft nut is torqued to 55 ft/lb and you partially compress the strut to do the job correctly. While most shops other than dealerships would not have a stock of specific GM tools and fixtures, there are "universal" tools for the job.
    FWIW the 3 upper strut mount bolts - 15mm - are torqued to 33 ft/lb, and the strut-to-knuckle bolts are 108 ft/lb. As with any recommended assembly work, check the GM manual for your model and year - values vary.
    Never, ever guess at torque values. You will be wrong - and most times very wrong - every time. There are good, specific, safe mechanical reasons for determining and using torque values. To recommend otherwise is to condone unsafe shadetree practices and could well cost someone life or limb. Do it right or don't do it at all.
    The old torque value of "Squeak tight plus a quarter turn" has no place in today's precision assemblies and metallurgy.
    I would take any advice to ignore recommended torque values with a very big grain of salt: You are likely to break something or hurt someone. For some one to post that they openly ignore published assembly values is dangerous and is a practice specifically NOT recommended by any service manual in existence.
    Oct 2004
    Oak Creek, WI
    5,609
    Says the guy who doesn't seem to understand it, Mr. 33 "ft/lbs"...
  16. #14
    Feb 2006
    55,936
    Would "lb ft" or a conversion to "N-m" satisfy your shadetree instincts ?
  17. Remove Advertisements
