engine noise
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, engine noise in Past Cadillac Vehicle Discussion; when my car is at idle it makes a woodpeeker noise then it stops ,few minutes later it startes back ...
    pman is offline Cadillac Owners Member
    Nov 2004
    Exclamationengine noise
    when my car is at idle it makes a woodpeeker noise then it stops ,few minutes later it startes back ,an it keeps doing it. what is going on with 94 sedan deville
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Re: engine noise
    With engine off try to turn the alternator (belt on) or anything on the serpentine belt. If it moves much at all, check the harmonic balancer. The 3800 V6's fail the rubber ring from the belt to the hub and it rattles like crazy. It will add harmonics to the crank, but I had to drive mine (3800) over 380 miles till I figured out what it was. It didn't hurt it, but sure is embarrassing to drive!
    Tom
