Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Cylinder #8 on 2002 Cadillac Deville Base
    Smackdaddy66's Avatar
    Smackdaddy66 is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac DTS
    Dec 2011
    Granite City, Illinois
    42
    60
    I have cylinder #8 misfiring on my Deville Base. I am attempting to track down the issue. So far, I've been told it is far right in the front of the motor. Either way, replaced all four plugs on the front end, and boots, ordered the coil pack. Still misfiring as of right now, have yet to replace the coilpack, however, am I even on the right side for cylinder #8, or is it possibly in the rear? Just making sure I'm narrowing down the right side. I intend to replace at least the plugs and the boots on the rear side within the next few days, but you can only do as much as the money allows for the time being. I've used OEM Ac/Delco plugs, an aftermarket boot however, and the coilpack on it's way is a Delphi, OEM. It was suggested in an earlier post that the coilpack aren't necessarily know for malfunction, so it throws into question whether or not I'm even on the right track. Any help is appreciated.
    Sep 2003
    Metro ATL
    4,854
    Re: Cylinder #8 on 2002 Cadillac Deville Base
    Quote Originally Posted by Smackdaddy66 View Post
    How do you know cylinder 8 is the one mis-firing?
    Well, the coil packs do fail.
    Have you displayed the diagnostic codes? Your codes can be displayed on the DIC. Here's how:
    http://www.cadillacforums.com/forums...-sevilles.html
    For a misfire, the "P" codes are the important ones. Tell us what you learn.
    Dec 2011
    42
    60
    I have a friend who is a mechanic, he hooked up a scanner, while driving it, cylinder #8 constantly misfiring. Engine light is not on, it came on after it first started and went off. When he pulled it up, misfire.
  5. #4
    Sep 2003
    Metro ATL
    4,854
    Untill something sets a "P" code, you are shooting from the hip in the dark.
    It could be ignition or it could be a fuel injector.
  6. #5
    Dec 2011
    42
    60
    The "P" code in there is a PCM P0300 History. Where can I go to decipher the other codes?
    DDM U1713 History
    RCC B1009 History
    VTD B1327 History
    Very informative information thus far, thanks!
  7. #6
    Sep 2003
    Metro ATL
    4,854
    The "P" code in there is a PCM P0300 History. Where can I go to decipher the other codes?....
    That is a limitation of the DIC code display. The PCM will certainly set a P0308 code, but the DIC will not display a specific cylinder code.
    Since you DO NOT have any other "P" codes, I would say it is reasonable to expect that replacing the front bank ignition cassette will solve your P0300 issue.
    The other codes you mentioned have nothing to do with engine controls.
    The B1327 code tells us you have had a battery voltage issue in the recent past. Has that been resolved?
  8. #7
    Dec 2011
    42
    60
    I believe so, that was one of the first checks on advice of a friend. Positive connection was loose, DIC shows 14.6 volts and ok.
  9. #8
    Hipoint's Avatar
    Hipoint is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Deville DHS
    Oct 2009
    638
    Coil pack should fix it...
  10. #9
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,748
    Keep us posted. The solutions are always good for future reference.
  11. #10
    69
    82,262
    http://myweb.accessus.net/~090/dtcobd2.html
    Standing in front of the car, looking at the engine, the cylinders are numbered as such.
    1 3 5 7
    2 4 6 8
  12. #11
    TexasGuy is offline Cadillac Owners Member
    Automobile(s): Deville 97
    Jul 2010
    38
    84
    I have a similar issue with 1997 Deville, I had P0305 (5th cylinder misfire). Changing wireset and spark plugs did not help. Then, I put in a fuel cleaner into the tank, in 2-3 days the misfires are no longer happening, rough idle is not as bad. This all points to bad injectors which I will be replacing very soon (once they will arrive).
  13. #12
    Dec 2011
    42
    60
    Update:Cylinder #8 Misfire,2002 Cadillac Deville, Base, from previous post
    Well, the ignition bank solved the problem. Thanks to everyone who posted their advice on the situation. After replacing plugs, boots, and ignition bank, she's running smooth again. I don't know if it was the ICM or the bank itself, because the new one came with the ICM, however, it solved it. Bought the bank online at carpartswholesale.com, give a shout out to them, $157 tax, shipping and everything, took around 4 days to get it. Once again, thanks everyone!!
  14. #13
    Brett Maverick's Avatar
    Brett Maverick is offline Cadillac Owners Member
    Automobile(s): 98 Deville
    May 2013
    8
    Re: Update:Cylinder #8 Misfire,2002 Cadillac Deville, Base, from previous post
    Ok I got a similar problem with my 98 deville. P0308, P0131 and P1133. I know the last two codes have to do with the O2 sensor. I just bought the car used at 72K original miles (a granny car) but this is the problem. I have swapped out the coil, the wires, the plugs (OEM) and even the ignition control module and finally the injectors. I still get the cylinder 8 misfire code. Is there a module, maybe the ESM that might be bad. Thoughts??
  15. #14
    69
    82,262
    Without the code definitions we have no idea what those codes are.
  16. #15
    May 2013
    8
    Ranger, Thanks, Sorry had to have surgery and have been gone a while. P0308 misfire #8 cylinder, OBD II P0131 Oxygen Sensor Circuit Low Voltage (Bank 1, Sensor 1), P1133 = HO2S Insufficient Switching Bank 1 Sensor 1. So to square one, could it be that the ESM sensor is bad as I dont see how the O2 sensor would interfere with just one cylinder.
  • You may not post replies
