2002 Deville - Heater/AC blower motor problems - Quick Fix
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2002 Deville - Heater/AC blower motor problems - Quick Fix in Past Cadillac Vehicle Discussion; This was a quick fix that I did to restore function to my blower motor. Just wanted to post this ...
    MinnesotaDeville is offline Cadillac Owners Member
    Automobile(s): White 2002 Cadillac Deville, Cream color soft top
    Oct 2011
    31
    8
    Smile2002 Deville - Heater/AC blower motor problems - Quick Fix
    This was a quick fix that I did to restore function to my blower motor. Just wanted to post this because I noticed a lot of threads pleading for help but really no solutions. This is just one thing to check before ordering a new blower motor.
    Symptoms I was having
    - Blower motor not working, minute heat or no air blowing out the dash/defrosters/floor. ect...
    - Occasionally works turns on and off
    - Slamming the right hand side passenger door would temporarily fix the problem
    - Tapping on the blower motor metal housing with the handle of a screw driver would temporarily fix the problem
    - Wiggle the blower motor power source - Blower motor turns on and off
    - Wiggle the housing - Blower motor turns on and off
    Quick Fix - Take blower motor out from underneath the dash (passengers side - 3 screws). Took the metal housing off the bottom of the motor so you can see the brushes and the copper color metal that they come in contact with. I took a small file and filed the brushes slightly. Then I took the file and filed away the musty tarnished brass/copper or what ever the metal is. Got it nice and shiny again. The sub housing that holds the brushes, remove that from the main housing. You will need to pinch the brushes to retract the springs so you can get the sub housing back on the contact. Then put the main cover or housing 2 screws back on, plug the blower motor back in and she should start spinning. That was just my case and what I did to fix it. If you have some of the symptoms above you might want to try it. It will save you some $$$ about $250 from the stealership.. Ebay has new motors for about $50. This whole ordeal took me about 45 mins with a broken knee... Anyone is capable...
    Hope this helps as thats all I am trying to do, I know my parts terminology is not up to par... GOOD LUCK!!!
    69
    82,377
    Re: 2002 Cadillac Deville - Heater/AC blower motor problems - Quick Fix
    Thanks for the post. I copied this to the Tech Tips forum and changed the title to read 2000-2005 Deville etc.
    polorico is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    Dec 2011
    27
    49
    I hear a sound underneath my dash as well . I think its the blower motor , My heat runs hot then slows down....
    So i should do this trick to fix the problem ? great thread
    mike5514 is offline Cadillac Owners Enthusiast
    Automobile(s): 97sls,09dts
    79
    878
    Thanks for the tip Im a strong believer in taking things apart (when possible) and try to repair before I buy new.Mike
    69
    82,377
    Quote Originally Posted by polorico View Post
    The fan speed is supposed to slow down as the cabin reaches it's requested temperature.
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,658
    Quote Originally Posted by MinnesotaDeville View Post
    Take blower motor out from underneath the dash (passengers side - 3 screws)... This whole ordeal took me about 45 mins with a broken knee... Anyone is capable...
    Nice fix... I see that you are one of the lucky 2002 Deville owners that has the design 2 blower assembly. What's the build date on your car?
    Design #1 ran from 2000-2002 and is a PIA to change... more than 3 screws and the assembly is too large to pull from under the dash... hence the design change.
    Design #2 ran from 2002-2005 and has a much smaller housing and simple to change (only 3 screws).
    The usual problem with the design #1 blowers is a broken wire (bare copper) that runs to one of the motors brushes.
    Exactly... it does this by PWM (Pulse Width Modulation) you won't see a voltage decrease going to the motor on a meter as the motor slows down. You would see the spacing between the pulses of DC widening on an Oscilloscope in the unlikely chance that anyone on this board actually owned one.
    Now that I've said that I'll probably here from all the pencil necks that do own one.
    69
    82,377
    Not me. Ain't too many tools I don't have, but that is one of them. Wouldn't know how to use it anyway.
    BTW, I copied the upper portion of your post to the Tech Tips thread as well. I thought it was pretty relevant to anyone who reads it in the future.
    00 Deville's Avatar
    Mar 2004
    Wilmington, NC
    52
    2,658
    I was wondering how that got over there... Nice work.
    saler11 is offline Cadillac Owners Member
    May 2012
    47
    1
    I just fixed mine the easier generation with three bolts. All i need was sand paper and some wd-40. Great article for a great direction! Thanks
    Chuckly is offline Cadillac Owners Member
    Automobile(s): 2005 deville
    Feb 2014
    Daytona Beach
    1
    I'm having a similar problem on my '05 DeVille. How do you get the fan out?
    Thanks in advance!
    - Chuck
    69
    82,377
    Just remove the passenger side lower insulator panel and it's right there. You could remove the knee bolster above it if you want more room, but remember, it pulls straight out NOT down.
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    57
    388
    Re: 2002 Deville - Heater/AC blower motor problems - Quick Fix
    does any one know were brushes can be bought??? i have a spare motor that just needs brushes but i cant find them any were
    69
    82,377
    I'd check a local starter/alternator rebuilder. Otherwise check online. Don't worry if they are oversized. They are as soft as chalk and are very easily filed to size.
  16. #14
    griff's Avatar
    griff is offline Cadillac Owners Member
    Automobile(s): 2005 DeVille
    Dec 2015
    Saint Pete Beach
    72
    22
    Dear Minnesota: Thanks so much for your technical advice. My 147 thousand mile 2005 DeVille AC fan quit just after a battery replacement job. I had thought that the battery job had something to do with it, but my troubleshooting led me to the carbon dust filled AC motor. Your article guided me to solving the AC fan problem and my hat's off to you. Griff
  17. #15
    Pitdog is offline Cadillac Owners Member
    Automobile(s): 1988 Deville and 2004 Deville
    Apr 2015
    9
    I'd also like to say thank you for your detailed post. I was able to easily fix this issue at no cost using your tip. The motor looked pristine outside and was a corrosion horrorshow inside, with rust chips and nasty sconge everywhere. I shop-vac'd all that out, ground the brushes to shape and reassembled in about an unhurried hour. The passenger door-slam is a great interim fix until you have time to service the motor correctly. My wife thought I was The Fonz when she said the blower wasn't working and I told her how to get it going, LOL.
  18. Remove Advertisements
