95 deville dtc code p024??? Stuck in 1st will go neutral & reverse
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 95 deville dtc code p024??? Stuck in 1st will go neutral & reverse in Past Cadillac Vehicle Discussion; P024 (E024) ..................................... Vehicle Speed Sensor signal to TCC LEFT WINDOWS DOWN IN MY 95 DEVILLE AND RAINED, STARTED UP ...
    Jesse Brown is offline Cadillac Owners Member
    Automobile(s): 95 deville,, 91 brougham
    Nov 2011
    Holiday, Florida, United State
    31
    4
    Exclamation95 deville dtc code p024??? Stuck in 1st will go neutral & reverse
    LEFT WINDOWS DOWN IN MY 95 DEVILLE AND RAINED, STARTED UP BUT SPEEDOMETER STAYS AT 0 MPH WHILE DRIVING. ALSO STEERING COLUMN IS MUCH TIGHTER AND SO IS THE GEAR SHIFTER. AT LEAST 10 TIMES TIGHTER THAN BEFORE IT RAINED. STUCK IN 1ST EVEN IF I MANUALLY TRY SHIFTING 1ST - 3RD OR OVERDRIVE. PLZ HELP IVE ALREADY CHANGED TRANNY MODULATOR, FLUID, ADDED TRANNY CONDITIONER AND I CANT AFFORD TO DROP THE TRANSMISSION TO GET TO THE MULTIPLE SOLENOIDS AND SENSORS. EVERYTHING WAS PERFECT UNTIL THAT MAJOR RAIN STORM. COULD IT BE A CABLE BEHIND THE DASH?
    68
    82,057
    Re: 95 deville dtc code p024??? Stuck in 1st will go neutral & reverse
    Might try replacing the VSS. Part #10
    http://www.gmpartsgiant.com/Page_Pro...xID=GM04429K01
    Nov 2011
    31
    4
    what's the vss? and would that cause the gear shifter to be almost locked up?
    68
    82,057
    VSS = Vehicle Speed Sensor.
    No, that will not cause the shifter to lock.
    Nov 2011
    31
    4
    it stopped shifting after the dash n everything got soaked. it also caused the speedometer to quit working and wont register miles drivin. only thing working on the digital dash is the fuel usage. then tension on the shifter increased 10 fold... any thoughts?
    Nov 2011
    31
    4
    whats the best (easiest) way to change the sensor?
    68
    82,057
    That opens an whole new can of worms. Could be anything from a wet connector to rust in the shift cable. You're just gonna have to get into it and do some exploratory surgery.
    Never had to change the VSS on that trans.
    RLT Guest
    have a 93 cad seville sts. just replaced the shift solenoids now no forward gears unless i step on the throttle and hit 4000 rpm. everything but over drive worked before
  11. Remove Advertisements
