Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Top speed fuel cut off
    Oct 2004
    North Dakota
    38
    17
    Is there a top speed for the 2000 Devilles posted anywhere? I heard they cut the fuel off at 110 mph. Is there anyway to override it?
    jake
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Top speed fuel cut off
    Why would you need to override it if you don't even know what speed it is at....LOL LOL. Run the car up there and see where it is...
    Young DeVille's Avatar
    Young DeVille is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Dark Adriatic Metallic Blue Deville Sittin on 20 Chrome
    Mar 2004
    Washington, DC
    34
    328
    LOL I do 100 in my car like everyday. But on my 97 Deville the fuel cuts off at 112 and I'm no tech but I think you re-program the OBD and remove the restictor plate or govnor. Remember I said I think...
    If you can find a way let me know
  5. #4
    Oct 2004
    North Dakota
    38
    17
    It does shut off inbetween 110 and 111. It feels like you hit the brakes for second. And "Fuel Shut-off" lights up on the display below the Speedometer. Does anyone know of a good company that they have experience with that has been able to over ride this.
  6. #5
    Dec 2002
    52
    9,577
    I'm afraid you are out of luck. The speed limit that is set in the PCM is based on the tires the car was equipped with at the factory. Thank the trial lawyers and frivolous lawsuits for the speedlimiter as the tire and auto companies are extremely sensitive to this. To change the speed limiter the PCM would have to be reprogrammed and the PCM that is in the 2000 and later FWD Northstar Cadillacs is very difficult to hack and can be rendered brain dead very easily if tampered with.
  7. #6
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Is the difficulty in circumventing the limiter just due to its nature, or is it because if someone figured out how to tell thier car through the overrides menu that it was equipped with Z rated tires and ran it to 150 mph with 4 doughnuts its "STILL GM'S FAULT BECAUSE I COULD" ..type of issues?
  8. #7
    Dec 2002
    52
    9,577
    Quote Originally Posted by DaveSmed
    Yes.
    It is technically difficult to change the speed limiter in the PCM because improperly accessing the data in the PCM can easily "brain dead" it. Also, there are calibration check sums in the algorithms so just the speed limiter value cannot be changed alone. The checksum has to be changed also. This is a means of checking the fidelity of the cal in the PCM as part of the onboard diagnostics as well as a means of protecting the PCM against hackers.
    People have wrecked cars at high speed and then sued GM and the tire manufacturers because "the tires were not capable of the speed they were driving.." so...now you get speed limiters that are at the rated speed of the tire. Since a tire that is constructed and rated for high speed use is typically NOT the same tire construction wanted for ride quality and fuel economy it is typical to have lower speed rated tires on most vehicles. Higher speed rated tires come on cars with the performance capability and with an anticipated clientel that will appreciate (or tolerate) the ride quality of the high speed tires. Case in point. Cadillac equipped all the 93 STS cars with the Z rated tires and no speed limiters. Tons of ride quality complaints due to the harsher ride of the high speed tires. Later on, in 96 the Z rated tires were optional and the cars were shipped, unless otherwise specified, with lower speed rated tires that rode "softer". End of complaints about ride quality and almost no complaints about the speed limiter that was included. So....what would you do...???
    Any car built without a speed limiter has the tires from the OEM with the high speed rating. IF the owner drives too fast and wrecks and doesn't have the high speed tires on then at least it is defensable that the car was shipped with the correct tires and that they were changed later. It would, admittedly, be hard to defend if a car that could go 150 were shipped with tires good for 125 and then the owener wrecked and blamed the tires coming apart at high speed..... So...there is implicitly a legal liability involved with removing the speed limiter from any car...which is why it is hard to get someone to do it and why it is protected from hackers as much as possible.
  9. #8
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Build a circuit to half the speed sensor output. Trigger it with a toggle switch when you get to near max speed. You have to be careful, the car TRUSTS that sensor, and when it is reading 50mph and you punch it, it will downshift, even at 110 mph.... Use at your own risk....
    Another thought, (bbob?). Dead sensor it. Disconnect the Speed Sensor, the ECM will have to go to default values for transshifting and speed limiting, what will it do? I wouldn't think GM would stop the car do you?
    As for faster, check and see if you can reflash for overseas calibration. Germany would likely be faster.... But getting your local GM Shop to flash might be tough.
    Tom
  10. #9
    Feb 2003
    37
    122
    Not all Devilles are limited to 110 (if any actually are). I know mine will do 130. So if you're just looking for another 20 miles per hour you might find out which Devilles have the higher limiter. Mines a DTS so I assume all DTSs will do it. Some DHSs might as well. Once you know, you might get the PCM reflashed or replaced with one from a car without a limiter.
    Scott
  11. #10
    Mar 2004
    800
    Y U need 2 got so fast??
    If you get to work dead. you wont be anygood to anybody.
    Y not take your time. live 2 C another day
  12. #11
    DaveSmed's Avatar
    Aug 2003
    Bucks County, PA
    30
    2,795
    Quote Originally Posted by MrSmith
    Some people like to take thier cars to the track.... not to go to work fast.
    Gotta love personal responsibility... the very reason we need stuff like this.
  13. #12
    Sep 2004
    19
    Mr. Smith,
    In that case why not drive to work at 15MPH, or better yet walk, or maybe work at home.....well the possibilities are endless. Life is so much more fun with a little risk involved. No long boring life for me, but then again that's just me.
    Mr. Flea
  14. #13
    69
    82,272
    That's the problem. it's not just you on the roads.
    Think about life as a paraplegic or a double amputee. It can be pretty boring.
  15. #14
    klebrun's Avatar
    klebrun is offline Cadillac Owners Fanatic
    Automobile(s): 1988 Sedan Deville
    Dec 2003
    410
    Quote Originally Posted by FLEALAMI
    Mr. Smith,
    Mr. Flea
    Maybe Mr. Smith misunderstood what someone was trying to say in this thread, I don't know, but your comments do not reflect what he was trying to convey, and it does you a disservice to take them to these extremes. I can only assume from what you stated that you advocate taking these "risks" during a normal drive to work. I am all for a person taking their car or bike to the track, or to a lonely highway on a late Sunday night to do a performance test. It's difficult to resist the temptation to "see what it can do". But this is a matter of your personal responsibility to other drivers on the road, some who have children in their cars. If you want to take risks and possibly shorten your life, make sure it is you...and only you...that will suffer the consequences if something goes wrong. If you feel your driving skills are so good that you think "it can't happen to me", you're kidding yourself. Even pro race car drivers get into accidents. Your risk taking fun does not supercede the right of any individual or family to make it home without being mamed or killed. If you are just joking or if I have misunderstood what you meant, then please forgive my rant and accept my apologies. But if you are serious, you need to realize the limitations of you and your car, especially in traffic. Anyone that does performance driving on a regular basis will tell you..."Respect the Beast".
  16. #15
    Sep 2004
    19
    To all ye who find it acceptable to preach to those that don't abide by the almighty 55, would you please show me where I advocated high speeds with traffic around? Actually I usually do 65 on I-95 but I have reached the Devilles cutoff point when nobody was around.
    Mr. Smith questions the need "2 got so fast??". My point is that if you are really so concerned about spending your life as a quadraplegic or killing the children then perhaps you should slow down from your "acceptable" speed. The problem is that everyone has their own acceptable speed. Remember that the guy in front of you is always the "road hog,idiot" and the guy tailgating you is the "maniac". You are "just right."
    That's why I like my second car...it goes 500mph, no tickets, and nobody preaches to me.
    Flea
  • You may not post replies
