E40 code rough idle lack of power
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, E40 code rough idle lack of power in Past Cadillac Vehicle Discussion; I have been doing a lot of reading on this but have not come to a solution exactly. From what ...
    TravisJamesBarrett is offline Cadillac Owners Fanatic
    Automobile(s): 1993 deville
    Jun 2011
    30
    113
    From what I see the power steering pressure switch is supposed to be on the steering rack, mine is located on the passenger side of the car near what looks like a cooler of some sort. It is a metal power steering line for sure. Anyway I broke the sensor off, I put it back together figuring since I only broke the snap ring it would work, I was wrong.
    However I also have no A/C and it seems to be starting in the wrong gear unless I manually select 1st.
    Is this the same problem or is this a fuse I am looking for. I have checked all fuses, the ones inside the car on the drivers side and the ones under the fuses/relay cover in the engine bay and found nothing.
    Im going to buy a new sensor tomorow but is this likely the only problem with the car does this sensor really have that much control over the car
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: E40 code rough idle lack of power
    Under the dash on passenger side, remove the hush panel. There is a fuse relay center. Check the fuses.
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    WinkRe: E40 code rough idle lack of power
    yes he right check that fuse, if i rember right its a 20 or 25 amp fuse and controls I few sensors if it keeps blowing check for a short at the A\C Pump.
    Jun 2011
    30
    113
    AC compressor is on its way out, that fuse was blown also the sensor was shot thanks for info on where the fuses were
    DReffects's Avatar
    DReffects is offline Cadillac Owners Fanatic
    Automobile(s): '93 Sixty Special 4.9l V8, '01 Sebring Convertible, '13 300C
    May 2013
    Germany
    338
    THANKS, had that problem too! 15AMP fuse blown. Didn't find the scource though. simply blown, replaced, working^^
  8. Remove Advertisements
