2002 deville rough idle HELP! - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 35
Like Tree3Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2002 deville rough idle HELP! in Past Cadillac Vehicle Discussion; The SES light will go out after 3 ignition cycles with the failure not detected OR you can go into ...
  1. #16
    69
    82,159
    Re: 2002 deville rough idle HELP!
    The SES light will go out after 3 ignition cycles with the failure not detected OR you can go into the onboard diagnostics and clear it.
    Technically, EVERY nut and bolt on the car has a torque setting. That said (Sub may disagree), I rarely ever use a torque wrench other than on lug nuts.
  2. #17
    816rider is offline Cadillac Owners Member
    Automobile(s): 2002 STD Deville
    Apr 2011
    41
    43
    well after my 2 drives, the SES light is still on...the car has been started prob 10 times today...can someone steer me in the right direction on how to clear the SES? also should i clear all of the other codes and start fresh to see what pops up?
  3. #18
    Apr 2011
    41
    43
    took a short drive to the gas station this morning to put in some techron...looked down and the dash was free and clear of that monster light known as the SES! thanks guys for all your help! my next challenge will be the fuel sending unit? so my gas guage takes a chill pill! unless the magic bottle of techron works?
  5. #19
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,568
    [QUOTE=Ranger;2624187]That said (Sub may disagree)
    I don't use a torque wrench on everything, either...............but when you're fooling with plastic manifolds and cast throttlebodies I figure it's good politics to advise a relative novice to use torque specs instead of "squeak tight + a quarter turn".
  6. #20
    2002 DHS is offline Cadillac Owners Member
    Automobile(s): 2002 DHS
    Dec 2012
    19
    Submariner
    I read several posts about having rough idle conditions. It sounded like my plenum was bad so I replaced it even though the one I pulled out fine. A friend recommended the IAC and I cleaned it, still no better. What else can it be?
    Dan
  7. #21
    69
    82,159
    Have you cleaned the TB?
  8. #22
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,558
    Quote Originally Posted by 2002 DHS View Post
    Submariner
    Dan
    NEVER start by throwing a bunch of parts at a problem -
    DIAGNOSE the problem FIRST -
    THEN replace what is required - if anything -
    STEP ONE - ALWAYS -
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
  9. #23
    Dec 2012
    19
    Today I put on a used IAC and the car ran the same. About 800+ RPMs it runs smooth but idle is rough to very rough and sometimes stalls.
    codes
    ABS C1287
    IPC U1000
    IPM B0429
    PCM P1189
    thanks
    Dan
  10. #24
    69
    82,159
    Reread last line of post #22.
  11. #25
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,558
    codes
    ABS C1287
    IPC U1000
    IPM B0429
    PCM P1189
    thanks
    Dan
    it is CUSTOMARY to include the DEFINITIONS of any codes you may have -
    there are too many to have them all memorized -
    and like Ranger asked -
    have you cleaned the Throttle Body?
  12. #26
    Dec 2012
    19
    I did clean the TB. The codes are all not relevant to the issue. I don't know what to try next and can't afford a dealer. any ideas?
  13. #27
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    How many miles on the car?
    Any history codes?
  14. #28
    Dec 2012
    19
    93000 miles
    the codes I posted were all current accept the ABS.
    What are the ID numbers after the codes?
  15. #29
    69
    82,159
    Those numbers ARE the codes.
  16. #30
    Dec 2012
    19
    Ok I'm confused. It asks it you want ALL CODES? I hit yes and then it starts listing them. Then it asks if you want to CLEAR ALL CODES? I hit yes. Then it asks ID? no takes you back to the start and yes takes you to more codes.
    If the IDs are the codes then what are the first set of numbers?
  17. Remove Advertisements
