96 Deville ride issue
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 96 Deville ride issue in Past Cadillac Vehicle Discussion; When I hit a pretty good bump the rear end of the car steps out to the right. Is this ...
    CadillacSE's Avatar
    CadillacSE is offline Cadillac Owners Member
    Automobile(s): Two 1996 Sedan Devilles
    Apr 2011
    Woodstock, IL
    46
    23
    When I hit a pretty good bump the rear end of the car steps out to the right. Is this a problem with the air ride? I can't imagine that is normal. The car sits level and rides nice other than that. Anyone have or hear of this problem?
    68
    82,081
    Re: 96 Deville ride issue
    Hi neighbor!
    It's not the ELC. It's more likely worn control arm bushings or you are in need of a 4 wheel alignment.
    CadillacSE's Avatar
    Apr 2011
    Woodstock, IL
    46
    23
    Good point! I'll check the bushings and have her aligned then see how she does. Thanks neighbor!
    68
    82,081
    Check the bushings first. An alignment is a waste of money if they are bad.
    CadillacSE's Avatar
    Apr 2011
    Woodstock, IL
    46
    23
    Yes of course. Don't want to put the cart before the horse. Thanks again!
    mutz is offline Cadillac Owners Member
    Automobile(s): 1996 and 2002 Cadillac SDV
    Dec 2007
    Toronto Canada
    74
    check shocks or replace with Arnott
  9. Remove Advertisements
