2003 Deville Overheating!!!!
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2003 Deville Overheating!!!! in Past Cadillac Vehicle Discussion; I have a 2003 Cadillac Deville that is overheating. It seems like the only time it overheats is if it ...
    03caddyman is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Deville
    Mar 2011
    31
    3
    Exclamation2003 Deville Overheating!!!!
    I have a 2003 Cadillac Deville that is overheating. It seems like the only time it overheats is if it is idling on a hill, uphill. It doesnt when im stopped at a light or running or driving. I recently replaced the thermostat and it didnt fix the problem. I had the coolant flushed a few weeks ago so it has good coolant and is full. The fans do work but i have had alot of people say that maybe a relay or the temp sensor might be bad???? Anyone have any suggestions as to what to do next?? Also no leaks at al as far as i can tell.
    70cougar is online now Cadillac Owners Enthusiast
    Automobile(s): 2002 DTS, 70 Cougar conv
    Dec 2009
    Connecticut
    734
    Re: 2003 Deville Overheating!!!!
    What do you mean by "overheating"? What temp?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,141
    Sounds normal to me................
    Mar 2011
    31
    3
    Temp guage goes all the way up and then the intrument panel says a/c off and then that i need to idle car. so the temp guage tops out.
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,658
    Quote Originally Posted by 03caddyman View Post
    I have a 2003 Cadillac Deville that is overheating..... I had the coolant flushed a few weeks ago so it has good coolant and is full.
    Did you have an overheat problem before the cooling system was flushed a couple of weeks ago?
    Mar 2011
    31
    3
    Yes it had done it before. I had refilled the coolant with water when it did the first time and that was part of the reason i had the radiator flushed.
    69
    82,383
    If it's going into the red and the cooling system is in good condition, you need to get a block test kit and check for exhaust gases in the surge tank.
    00 Deville's Avatar
    Mar 2004
    Wilmington, NC
    52
    2,658
    If your overheating... then having to add coolant... then do as Ranger says and do the block test before spending any more money on the car.
    amreed12 is offline Cadillac Owners Member
    Automobile(s): 2003 Deville
    Aug 2013
    36
    1
    My 03 Deville is doing the same thing. Wondering what you did to fix the issue before I go broke trying to figure out what is wrong.
    69
    82,383
    Don't hold your breath waiting for an answer. 03caddyman hasn't been here since 03-30-11.
    Do a search for overheating. LOTS of info on it. Start with the cheap and easy stuff, purge line, WP belt tensioner, surge tank cap.
  13. Remove Advertisements
