Block Heater?
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Block Heater? in Past Cadillac Vehicle Discussion; Imported my vehicle (1995 Deville) from the US to Canada. I assume the vehicle does not come all ready equipped ...
    fivealex@gmail.com is offline Cadillac Owners Member
    Automobile(s): 1995 Deville
    Dec 2009
    20
    UnhappyBlock Heater?
    I assume the vehicle does not come all ready equipped with a block heater?
    (Just called my local dealer to inquire of the cost...forget the cost ($500-600), the dealer said it would require two block heaters...does not sound right?)
    Thanks, Alex
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,243
    Re: Block Heater?
    Quote Originally Posted by fivealex@gmail.com View Post
    Thanks, Alex
    If you have a Northstar (update your profile to show your car, model, engine) there are 2 block heaters - Calrods which attach to the block sides and join at an underhood mains plug.
    Not sure if it's a 4.9
    Talk to rippypartsmaster, www.rockauto.com, or www.gmpartsgiant.com
    Dec 2009
    20
    Re: Block Heater?
    1995 cadillac deville 4.9l
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    Re: Block Heater?
    Thanks, Alex
    Actually, I've owned two 92 eldorados and they both had 2 block heaters each.
    Nov 2005
    3,013
    Re: Block Heater?
    Quote Originally Posted by submariner409 View Post
    My 92 eldos. had a male plug for each heater, 2 male plugs per car.
    MRneatfreak's Avatar
    MRneatfreak is offline Cadillac Owners Member
    Automobile(s): 1994 (4.9) & 1997 (4.6) Deville
    Jul 2010
    SW Florida Panhandle
    40
    Re: Block Heater?
    While I have used the block heater on my two of my Oldsmobile's 1 diesel, 1 gas. It uses only one (307), and works great! I know the pain of removing the freeze plug and installing and praying it doesn't leak. Which leads me to thinking of using a tank heater which costs just as much, but is easier to install and takes up a little more space. I too am thinking for use on both of my 4.9L and 4.6L Caddy's. Might check out the tank type?
    mutz is offline Cadillac Owners Member
    Automobile(s): 1996 and 2002 Cadillac SDV
    Dec 2007
    Toronto Canada
    74
    Re: Block Heater?
    Alex: I have block heater in my '02 SDV, I live in Canada and I have never pulled them in. This car starts so well, there isn't any need for them.
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,751
    Re: Block Heater?
    How cold does it get where you live? I've had -24F cold starts, and +11 cold starts the night after -40F, and she runs fine. I just let her warm up to idle.
    Feb 2006
    56,243
    Re: Block Heater?
    FWIW the 4.6 Northstar uses 2 Calrod elements bolted to the lower block sides. The electric cords Y into a plug that is either coiled up on top of the engine or hangs out the grille.
    It does not use a coolant heater because, given the setup of the cooling system flow path, there's no place to install a hose or tank convection heater.
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Re: Block Heater?
    I've used an inline heater from NAPA on several vehicles(no caddys though). easy to install and cheap.
  13. Remove Advertisements
