Rear Suspension/Shocks 2001 Deville - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 58 of 58
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Rear Suspension/Shocks 2001 Deville in Past Cadillac Vehicle Discussion; $159.39 each plus shipping ($25) for a total of $343.78...
  1. #46
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Rear Suspension/Shocks 2001 Deville
  2. #47
    01DevilleDave is offline Cadillac Owners Member
    Automobile(s): 2001 Deville
    Feb 2012
    47
    37
    After reading all of this Thread I am thoroughly lost........Can some one please tell me,
    If I have the replacement shocks that are making the noise as stated by mtflight .......is there a spring kit I can buy and fix this myself? I have had the same intermittent noise after replacing my shocks and just couldn't figure out why.
    Any help is appreciated!
  3. #48
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    Only thing that worked for me was adjusting the ride height so that the compressor fills them with more air. I'm not sure the spring did much other than consume a lot more time.
  5. #49
    Feb 2012
    47
    37
    Ahhh, Thank You for clearing that up!
    May I ask what you found was the best way to achieve a different ride height? I did a "search" under adjusting ride height and did not come up with much on the subject.
    Thank You!
  6. #50
    mtflight's Avatar
    Jan 2005
    Dallas, TX
    2,538
    Quote Originally Posted by 01DevilleDave View Post
    Thank You!
    Extremely easy fix. All that it requires is removing the rear driver side wheel, and you have access to the ride height sensor. You twist the little arm off and then you lengthen it a little bit see how I did it here http://www.cadillacforums.com/forums...ar-height.html
    My solution involved a clip, a bolt, and a nut. I adjusted it a few times until I had it just right so that the rear shocks remained full of air on a level surface, without raising the rear end more than a half inch.
  7. #51
    Feb 2012
    47
    37
    Thank You Very Much mtflight!!
    I will be doing that this weekend!
  8. #52
    mtflight's Avatar
    Jan 2005
    Dallas, TX
    2,538
    You're welcome. You should take pictures to see how you improvised it and help others too.
  9. #53
    Feb 2012
    47
    37
    I will have to remember to do that. Something tells me there will be some trial and error in getting it just right though.
    Thanks Again!
  10. #54
    VHP's DHS is offline Cadillac Owners Member
    Automobile(s): 2001 DeVille DHS
    Mar 2012
    Central Iowa
    54
    23
    What do you mean when you say (ACDeclco "additional usage" or "selldown" shocks)? Just curious. I'm struggling with the noise issue from the back end of the car. Dont know if its the shocks or control-arm bushings.
    Thanks
  11. #55
    Sep 2007
    Wilmington, NC
    13,986
    I'm guessing you're asking me since I'm probably the only one who uses those terms.
    In short they mean the non OEM versions of acdelco parts meant to compete with the aftermarket.
  12. #56
    carlos d is offline Cadillac Owners Member
    May 2013
    29
    3
    How did u open the dryer to install the spring?
    Big tone (off topic) but are u from Northern California?
  13. #57
    May 2013
    29
    3
    How did you open the dryer to install the spring?
  14. #58
    limoman69 is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac DeVille limo
    Dec 2016
    4
    Quote Originally Posted by gopher View Post
    This is timely information, however, to throw a wrench in the works, the AC Delco
    book quotes ABSORBER KIT,RR LVLG SHK DUAL PKG
    Part Number: 504-97
    Product Notes:
    [Rear Levelling Shock Absorber Kit(VPI 1-877-846-8243)]; Hearse Conversion (B9Q) ; Limo pkg (V4U) ; Hvy Duty Susp (FE7) ; Except; Armored body equipment (B05)
    Per Vehicle: 2; Years: 2000-2000
    for my application.... Its 6'' stretch ( 8 bolt rim) similar to the DES of previous years...
    Can the MA822 be used here, as Monroe indicates, too....?
    Thanks in advance
    Hey everyone I have a clunking noise in my right rear. I'm thinking it might be the shocks. Does anyone know for sure if the Monroe MA822 will work on my car. It doesn't seem like it will as far as this post. If anyone knows please paste a link for me...
    Oh I have a 2002 Cadillac Deville limousine.
    Thanks..
  15. Remove Advertisements
