Results 1 to 3 of 3
Thread: Tail light problem- 94 Deville
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    On my 94 Deville, the top tail light bulb has both filaments lit when the brake is not depressed. I can't figure out what it could be. Any ideas? I had just changed all the bulbs because the bottom bulb was out. The other two bulbs in the light are fine, just the top one has both filaments lit.
    Thanks!
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    Re: Tail light problem- 94 Deville
    bulb may be in wrong , remove bulb and note the heights of each fo the two side pins that are on the blub's metal base . then note the hights of each of the two slits in the socket the blub goes into
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Yep, that was it! I put the bulb in the other way and it works fine now.
    Thanks!
  • You may not post replies
