Spindle Nut Size 1986 Coupe DeVille
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Spindle Nut Size 1986 Coupe DeVille in Past Cadillac Vehicle Discussion; Can anyone tell me what size is the spindle nut of a 1986 Coupe DeVille? Thanks Adan...
    Adam Bronikowski is offline Cadillac Owners Member
    May 2004
    3
    Thanks
    Adan
    CadillacBlue5's Avatar
    CadillacBlue5 is offline Cadillac Owners Member
    Mar 2003
    Hollywood, CA
    48
    Re: Spindle Nut Size 1986 Coupe DeVille
    Well if you are talking about the axle nut which i am assuming also this car is RWD the correct size is one of the 4 using a 1/2" drive, they are 30mm, 32mm, 34mm, and 36mm. Hope this helped ya out. good luck.
