Radiator plug broken
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Radiator plug broken in Past Cadillac Vehicle Discussion; It appears that my radiator plug has broken. Suddenly the coolant emptied & I have no clue as to the ...
    GordonOKC is offline Cadillac Owners Member
    Sep 2004
    Oklahoma City, OK
    It appears that my radiator plug has broken. Suddenly the coolant emptied & I have no clue as to the reason. It seems I can feel what may be the remains of the plug at the back botton driver's side of the radiator. What I can make contact with is level with the opening. This where the coolant drains out when I tested it to discover the source of the leak. It's difficult to reach with a tool. Any suggestions for removal/replacement?
    This is a 1995 Deville 4.9 L
    On edit: Could what I'm feeling be a ring or something that needs to stay?
    Sep 2004
    Oklahoma City, OK
    Re: Radiator plug broken
    There are indeed two parts to the radiator stopcock. The stopcock or plug itself and a collar that fits inside the radiator. In my case the collar cracked which caused the original stopcock to go flying to where-ever. Apparantly this requires pulling the radiator in order to reach the collar inside the drain/radiator.
    The radiator shop told me that "sometimes" the collar will develop a crack causing the stopcock to come out.
    I hope this helps others that experience this problem; hopefully this does not happen often or to you.
