1993 Deville Clock Stays On
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1993 Deville Clock Stays On in Past Cadillac Vehicle Discussion; I have a 1993 Sedan Deville and with the key off the clock stays on constant. I am aware that ...
    CadillacEtc's Avatar
    CadillacEtc is offline Cadillac Owners Fanatic
    Automobile(s): 2016 SRX Performance, 2006 STS 4,
    Boston, MA
    232
    I have a 1993 Sedan Deville and with the key off the clock stays on constant. I am aware that if you turn the key off from running the radio stays on for 15 minutes untill a door is open, but this is not the case cause the clock is constantly on. Anyone else experince this problem?
    Thanks for help in advance
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    29
    2,795
    Re: 1993 Deville Clock Stays On
    So the radio shuts off, and the clock stays on? Try lightly tugging on the volume knob, or pushing it a few times. Normally with the radio off (opened door, whatever.) you can push the top knob to display the clock regardless. BUT it should disappear after a couple seconds. maybe your button is just stuck?
    Sandy's Avatar
    Sandy is offline Cadillac Owners Master
    Automobile(s): '93 Cadillac 60 Special; '03 Lincoln TownCar Limited ED
    Oct 2003
    Northern New Jersey
    70
    5,929
    I have had that 2 times. Both times it resulted in a nice very dead battery, as it was in the garage (wintertime) and I did not discover it for days....maybe a week. 2 times in 12 years. I think it has something to do with a wire in the door. When you open the door to exit, I think it's suppossed to go out...Yes ??
  5. #4
    Boston, MA
    232
    I checked all the doors, but again the radio shuts off the clock just stays on. I am aware that when the car is off u can press dial in for the time to illuminate. I am going to pull the radio out and see if it receving constant power or maybe the button is stuck. I get nervous because eventually it will drain the battery if it left for 2 days...
    If anyone else has ideas please let me know.
  6. #5
    Sandy's Avatar
    Oct 2003
    Northern New Jersey
    70
    5,929
    I checked mine.
    engine running, stereo on, clock is accessable, by pushing volume knob.
    shut radio, engine running, clock is showing
    shut engine off, clock stay illuminated for 10 minutes then goes off
    shut engine off, clock stays illuminated for 10 minutes,
    UNLESS I open door to exit. When I open door to exit....clock goes off.
  7. #6
    Boston, MA
    232
    I pulled the radio out and took my voltmeter to see what the story was. The memory wire is suppose to get constant power which it does. The power wire that is on switched ignition is working correctly.
    So to some this all up, the radio has a problem with it, I may look on ebay or put a aftermarket deck in and eliminate my battery drain. Thanks for your help
  8. Remove Advertisements
