Where can I get a digital speedometer for a 89-92 Deville?
Digital: Standard:
Speed sensor- Dk. Green Dk. Green
High Beam ind.- White White
Ground- Black Black
Ground- Black/White Black/White
Incandescent dim- Gray (X2) Gray
+12v Batt- Orange N/A (Tap in fusebox?)
+12v ignition- Brown Brown
E/M Switch- Lt. Blue N/A (Not needed)
VF dimmer- Purple/White N/A (Located at CCP/FDC)
16 Volt in- Orange/Black N/A (Located at CCP/FDC)
Seatbelt ind.- Yellow Yellow
LH Turn ind.- Lt. Blue Lt. Blue
RH Turn ind.- Dk. Blue Dk. Blue
Charge In- Brown Brown
Charge Out- Brown Brown
Change oil ind.- White White
Low Oil psi ind.- Tan Tan
Brake Ind.- Tan/White Tan/White
Airbag ind.- Brown Brown
SES ind.- Brown/White Brown/White
SVS ind.- Gray/Black Gray/Black
Coolant tmp ind.- Dk. Green Dk. Green
ABS ind.- White White
Eng. Metal tmp ind.-Lt. Green Lt. Green
Warning light pwr- Pink/Black Pink/Black (X2)
