A/C help
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, A/C help in Past Cadillac Vehicle Discussion; I have a 2002 deville the a/c blows very cold but the control will not work 99% of the time. ...
    lferrebee is offline Cadillac Owners Member
    Automobile(s): 2002 deville
    Mar 2010
    47
    4
    A/C help
    I have a 2002 deville the a/c blows very cold but the control will not work 99% of the time. It stay in defrost and floor mode will not switch over to come out the a/c vents plus i can hear a ticking sound behide the dashborad when i start my car up most times. it getting very hot in the atl so so help please. something more then taking it to the dealer or a/c place. thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,850
    Re: A/C help
    Air control and blend motor and actuator up in the dash in front of and beside the glove box.
    Use your car's built-in code reader/memory to get any Diagnostic Trouble Codes stored. At the top of this main Deville page - the sticky thread titled "How to pull codes" - read the whole thing and practice, write down any codes noting whether each is Current or History, return to the sticky and open the link with "obd2" in the URL to click on the lines in the Master Index box for the meanings of any codes found.
    68
    81,891
    Re: A/C help
    You should find a code for a mode door actuator or something like that.
    juliarae is offline Cadillac Owners Member
    Automobile(s): 2003 De Ville
    Jun 2010
    9
    Re: A/C help
    Hi - I am new here and hope somebody can help me. I am having a similar problem. I have a 2003 DeVille that just started clicking for a brief time when I first start the car. The air still blows cold, but now it blows out on my feet and not through the dash. From researching this forum I am pretty confident it is the mode actuator. On another post I saw an AC Delco p/n of 1572654 listed. But on yet another post I read to get the # off the bad part once you remove it. My question is this: Would I be okay to go ahead and order the actuator assembly so I have it when my mechanic tears into the job? (I have a great mechanic that moonlights and does it out of his home shop) Or do I have to wait until he pulls it off and then order it and wait until the part arrives? Also, the p/n 1572654 is the actuator assembly. Is that what I need, or do I need just the actuator only? Sorry if this is too lengthy or confusing! Please help if you can. Thanks!
  7. Remove Advertisements
