help with possiblle over heating?
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, help with possiblle over heating? in Past Cadillac Vehicle Discussion; so i just bought a 1991 cadillac deville.i hear a slight knock and the car is like the little engine ...
    aspen22186 is offline Cadillac Owners Member
    Automobile(s): deville
    May 2010
    25
    6
    Thumbs downhelp with possiblle over heating?
    so i just bought a 1991 cadillac deville.i hear a slight knock and the car is like the little engine that could.ill get up to fifty abd after a while when i seems to get warm it jus slowly wont go.so i have to stop for a bit to cool off.or so i think..what could be my options?
    May 2010
    25
    6
    Re: help with possiblle over heating?
    it also stalls somtimes and has a slight knocking sound
    revdowrong's Avatar
    revdowrong is offline Cadillac Owners Fanatic
    Automobile(s): 91 sedan deville
    Jan 2007
    san antonio, tx
    34
    341
    check for codes by holding off and warmer then report back
    May 2010
    25
    6
    Quote Originally Posted by revdowrong View Post
    can you specify please?
    May 2010
    25
    6
    i went n held off n warmer n the only numbers or type of code was .7.0 were the gas mileage is.also service engine soon and service vehicile soon lights came on while holding buttoms.am i doing this right?
    70cougar is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 DTS, 70 Cougar conv
    Dec 2009
    Connecticut
    728
    Read these instructions to get your codes:
    http://www.cadillacforums.com/forums...odes-dtcs.html
    Then go here & look up the definition of each code that registers:
    http://myweb.accessus.net/~090/dtcobd1.html
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    This one might be easier for some of us:
    http://www.cadillacforums.com/forums...x-engines.html
    May 2010
    25
    6
    ive tryed over and o9ver but no codes.only thing is .7.0 witch means codes are done being displayed.please give any advice possible.im stuck here...
    Feb 2007
    Maine
    55
    3,310
    You must not have any codes then. There was a thread running just last week with these same symptoms. If you do some searching here you will find all the common maintenance that these cars need. It sounds like your fuel pump could be dying. You should check your Fuel pressure and vacuum.
    May 2010
    25
    6
    my fuel pressure while hot is 35 and when i give it some gas it drops to 30 ive heard that fuel pumps should be putting out 45 is this true and how to i check vacuum pressure?
    69
    82,162
    That fuel pressure is a little low.
    You check vacuum by pulling a vacuum supply line and plug a vacuum gauge onto it.
    Feb 2007
    Maine
    55
    3,310
    Yeah, that fuel pressure is too low, time for a new fuel pump
  15. Remove Advertisements
