I'm replacing the rotors and pads on my 1999 DeVille. The caliper has only a lower bolt. There is not one on the top. How do I get this caliper off along with the rotor.
Does the 1999 DeVille require a special tool to reseat the caliper piston? I have tried a C-Clamp on it and it does not seem to be going back. Any advise?
You must be talking about the rears. Swing the caliper up and off of the rotor on the upper pivot pin. Then if you need to remove it, slide it inboard and off of the pivot pin. You'll pop the dust boot off so be sure to reinstall it correctly when putting it back together.
Is this the same thread he posted earlier ??.............about a caliper with one bolt..............
There's another recent thread in here concerning the need to screw the puck back into the rear caliper - along with a half dozen others on the same subject in the past six weeks. :helpless:
Sorry, did not mean to be redundant. I just joined the forum two days ago and still figuring out how to navigate around the site. Thank you for your help. I'll give it a go.
Take a look at this - it's probably close to what you have - you can screw the caliper puck back in with needlenose pliers - it just takes time. The puck pattern lines up with the new pad pattern on the metal face.
Thanks for the help. Good advise. I went ahead and bought the cube. It was pretty cheap at NAPA. The second side went much smoother than the first. Not a hard job once I learned what I needed to know. Thanks again.
You may have cocked the piston in the cylinder. Loosen the C clamp, reset it and try compressing it again. It that doesn't help, it may be seized (rusted internally) and may need replacing.
tjnewt, I manually activated your CF account. Please check your trash and spam boxes for an e-mail from either AutoGuide or CadillacForums - make sure your browser accepts input from these.
Please update your profile to show correct info and time zone - or do you really live in London - GMT ?
This thread had been dead for 4 years. If your car is a 1999 model, perhaps the front caliper piston is frozen...... unlike the rears, it presses back into the caliper.
There is more info on brake work down in Cadillac Tech Tips.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
