Results 1 to 3 of 3
    Waltbeal is offline Cadillac Owners Member Cadillac(s) I Drive: 2003 DTS
    Mar 2010
    2003 DTS Voice recognition
    sometimes when i hit voice recog button it beeps and I give command and it works fine and will continue working ok the entire time i am driving car. Other times when i start car and hit button nothing happens, if i hold button iib for approx 15 sec it will say "ready" like it wants an Onstar command, itf it doesn't work properly when i start car then it will not work the entire time i am driving
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Many
    submariner409's Avatar
    submariner409 is offline If it won't run, chrome it..... Cadillac(s) I Drive: 2002 Cadillac F55 STS/56000mi., 2004 Ford F150 Super cab 4x4
    Feb 2006
    Maryland upper Eastern Shore
    70
    17,053
    Re: 2003 DTS Voice recognition
    Have you done the analog-to-digital OnStar upgrade ???
    Hmmmmm.........the antenna coupler is on the back window. There's a spring clip BNC plug (antenna lead wire) which goes into the side of the antenna base. Carefully pull that BNC off the base and re-insert it a couple of times. My OnStar did sort of what you describe before I had the conversion done, and fooling with the antenna cable cured that problem.
    70cougar is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 2002 DTS, 70 Cougar conv
    Dec 2009
    Connecticut
    152
    This happens once or twice per year with my 02. I found if you turn off the ignition & start right back up, it works fine again.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
