Remove power steering pump pulley 2001 Deville
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Remove power steering pump pulley 2001 Deville in Past Cadillac Vehicle Discussion; I'm getting ready to replace the power steering pump on my 2001 Deville. My book doesn't give many details, so ...
    chazwj is offline Cadillac Owners Member
    Automobile(s): Cadillac
    May 2008
    6
    I'm getting ready to replace the power steering pump on my 2001 Deville. My book doesn't give many details, so I'm wondering how the pulley comes off the pump.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,828
    Re: Remove power steering pump pulley 2001 Deville
    The pulley has a groove machined into the metal hub extension. A special GM part # puller is used which engages the groove and uses a center bolt to pull off the pulley. Another tool is used to press the pulley back onto the new pump. If you are patient and machinery-inclined, a 3-jaw gear puller can be ground so the jaws fit into the pulley groove.
    A local automotive machine shop can do the whole procedure. The pulley is pressed on within a tolerance of +/- .010" of the shaft/pulley bore being flush.
    Ernest Henn is offline Cadillac Owners Member
    Automobile(s): 2002 Deville DTS
    Dec 2009
    79
    33
    I have pulled lots of power steering pulleys off with a three jaw puller.But you have to but some long heavy gauge steel plate behind the pulley so that when you start pulling you don't twist or bend the pulley.Don't be in a hurry and slowly tighten the puller.It will come off.Good luck.
    Ranger is online now Cadillac Owners Member
    69
    82,269
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Some of the pullers that you borrow from parts houses will work, just make sure they are small enough lip to grab the hub in the middle of the pulley. Do not grab the outside edge or you will warp the pulley. From what I remember the 2-jaw puller from advance was small enough, but the 3-jaw wasn't.
    dirt_cheap_fleetwood's Avatar
    dirt_cheap_fleetwood is offline Cadillac Owners Master
    Automobile(s): 1990 350 Brougham (The cruiser), 1988 Mark VII LSC (The DD)
    Aug 2007
    Woodridge, Illinois
    27
    5,545
    When I did the PS pump on the Lincoln I bought the tool at Sears for $40. I figured I'll use it again someday on someone else's car.
    kdwellssr is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Deville
    Jun 2013
    North Central Arkansas
    9
    I've read the post about replacing the power steering pump pulley on 01 Cadillac Deville. Is there a way a individual can put the pulley onto the new pump?
    69
    82,269
    Yes. The puller is also used as an installer or you can simply press it back on with the bolt and a stack of washers.
    Jun 2013
    9
    Thank You. I will be attempting the change this weekend. I will be trying to makeshift a puller and the stacked washers. Should I make the pulley flush with the end of the shaft if I don't have a actual measuring device?
    69
    82,269
    Not positive, but I think it does go to the end of the shaft. Study the old one before you pull it.
    reppinshadyvill is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Nov 2012
    Central FL
    34
    205
    Mine is flush with the end of the shaft closest to the coolant tank. You can get the proper tool from harbor freight for $40 or less. It will make your life SO muche easier......
  14. Remove Advertisements
