Results 1 to 9 of 9
    elvislisa is offline Cadillac Owners Member Cadillac(s) I Drive: Cadillac
    Feb 2007
    25
    Best Brake Pads / Rotors for 99 Deville - Any Advice???
    Hi there, I am getting ready to do a front brake job and I'm going to be replacing both the front Rotors & Brake Pads.
    I've been searching all over the web trying to find something - but there are too many brands/options to choose from....without a lot of reviews available. My main goal is to do this on a budget...but yet trying to get best quality for my money. I don't want to put $300-400 into a car when I can get by with about $150-200 if I shop wisely.
    1999 Deville - Base - Standard - Front
    ROTORS:
    I've looked at the R1 Concepts rotors, seen the Wagner ones (Advance AP), Duralast ones (Autozone) as well as other brands like Centric and Raybestos. Don't want drilled! Would prefer a vented model.
    BRAKE PADs
    I've seen the Wagner Thermo Quiet, Raybestos, Bendix and Posi Quiet (from R1 Concepts). I was leaning towards Ceramic, but I've never had them before. Trying to cut down on the brake dust!
    My budget is around $120-150 for both pieces (rotors & pads).
    The only real advice I've seen given on here is for the Raybestos rotors/pads, but I'm trying to find out if anyone has tried anything else or if this is truly the best way to go?
    Thanks for any recommendations or advice!!! Planning on doing the job in about 2 weeks!
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Many
    99Classillac's Avatar
    99Classillac is offline Cadillac Owners Enthusiast Cadillac(s) I Drive: Ex-99 Deville owner, Now-04 DTS owner, and a 07 ZX6R pilot
    Nov 2005
    Silver Spring, MD
    27
    744
    Re: Best Brake Pads / Rotors for 99 Deville - Any Advice???
    Go to Autozone. They have rotors for about $30 each. Then buy their $30-40 pads and there you go. All for less than $100.
    submariner409's Avatar
    submariner409 is offline If it won't run, chrome it..... Cadillac(s) I Drive: 2002 Cadillac F55 STS/56000mi., 2004 Ford F150 Super cab 4x4
    Feb 2006
    Maryland upper Eastern Shore
    70
    17,135
    ...............just make sure you don't lose that AZ one year warranty: you may need it.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    Ranger is offline Cadillac Owners Member Cadillac(s) I Drive: White Diamond '03 DHS
    62
    39,465
    I'd bet you can get away for less than $100 at Napa as well and I'd trust their parts more than AZ's. Or try rockauto.
    TuneUpsNSuch is offline Cadillac Owners Member Cadillac(s) I Drive: 91 Coupe DeVille, 92 Sedan DeVille
    Jan 2010
    93
    When it comes to saving my ass and that of my loved ones, I never skimp on brakes! Other than OE, I use Wagner Thermoquiet rotors and pads. To reduce the wheel nasties I have used ceramic pads although they can sometimes be a little noisy when cold.
    bigtone is offline Cadillac Owners Member Cadillac(s) I Drive: 1998 Deville, (2) 2001 Devilles
    Jun 2003
    88
    I put Raybestos from Rockauto on my 98 Deville, after about 6 months they seem to be holding up well. On my son's 01 Deville, I put the better Autozone pads and rotors front and rear, I believe they were the Duralast, and I am impressed that they are doing well after 6 months also. They were priced about the same as the Raybestos, about $130 for the front.
    Nov 2005
    Silver Spring, MD
    27
    744
    Man I always put cheap ass rotors and pads on my DTS from Autozone. The pads are always Duralast. Every other pad change, I change the rotors. But they always seem to hold up good. I change the rotors not because they warp, I don't have a machine shop so I can't resurface the rotors and I won't throw pads on a rotor more than 1 time without it getting resurfaced. So I just change them to new rotors. It's cheap enough. I was gonna get a set of rotors resurfaced once, but they wanted $15 each rotor. Yea right so I just buy rotors.
    CoupeD is offline Cadillac Owners Member Cadillac(s) I Drive: 1993 Cadillac Coupe DeVille, 1989 Cadillac Coupe DeVille
    Feb 2010
    31
    80
    Quote Originally Posted by elvislisa View Post
    ROTORS:
    BRAKE PADs
    Ceramics are great breaks. Bendix is good, raybestos is awesome. I used to use a company called akebono. They make ceramic pads and the price was right. As far as rotors you can really get any brand. As long as you don't ride the brake and drive smooth.
    Remember to make sure your brakes have the little packet of grease in them. That is SO important to coat the shim with grease to make it quiet. ALSO if you HAVE sliding pins TAKE THEM OUT AND LUBE THEM UP. The main problem for breaks wearing down uneven other than driver habits is improperly lubed sliding pins.
    If you wanna get a lil nuts grab some steel wool or a steel brush and clean the caliper while you do the job.
    If you do the job right and use a good brand you should never hear a squeak and pads on my car last about 30-40k miles
    Dave S Texas is offline Cadillac Owners Enthusiast Cadillac(s) I Drive: '87 Coupe DeVille 4.1L FWD(New engine Dec '08)
    May 2008
    Austin(area), Tx
    66
    772
    AZ rotors are made in China. Raybestos is a very old-line American company. When I did a complete 4-wheel brake job, and I mean new rotors/bearings/pads/calipers/shoes/wheel cylinders/springs/seals/fluid, on my '87 I installed carbon-metallic pads and shoes(drums were turned). CM pads/shoes STOP NOW! That job cost right around $150 in my driveway.
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
