Dashboard beeping noise
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Dashboard beeping noise in Past Cadillac Vehicle Discussion; Hey everybody! I have a 2004 Deville and recently after I just had the oil changed and transmission fluid changed ...
    mgantt is offline Cadillac Owners Member
    Automobile(s): 2004 Deville
    Dec 2009
    30
    Hey everybody! I have a 2004 Deville and recently after I just had the oil changed and transmission fluid changed my dashboard sounds a continuous beeping noise when I start the car. It beeps about 5 times then it stops. Due to the weather in my area I assumed that it was the "Ice Possible" warning but I am in a completely different climate now and it still beeps. Does anyone have a clue what this mysterious dashboard beeping is? The car runs fine and there is no error messages.
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    Re: Dashboard beeping noise
    door open? seat belt off.
    buckle up and then try it first
    Dec 2009
    30
    Yes...I've actually tried both of those solutions to no avail. The door and seatbelt noise is more of a dull beep. This beep is high pitched and I actually counted the beeps at about 12. It only happens as soon as I start the car. As I said the noise appears to be coming from the leftside of the dashboard.
    68
    81,926
    Usually a beep is also associated with a flashing light (icon) or a warning message.
    rudyboogie is offline Cadillac Owners Member
    Automobile(s): 00 DTS (193,000 )
    Oct 2012
    Florida
    50
    30
    Hola, I was searching for that loud beep noise and stumble with this thread. The noise was loud and constant, maybe 5 to8 times almost the same characteristics of mgantt but notice the phone icon display on the radio, car was running fine with no in issues or codes. BTW Florida weather.....Seems strange, this is actually the second time in 6 month with 180,000 on the clock.
    Any comments to this issue would be appreciated.
    Princezdanielle Guest
    Did you ever figure it out? Ours is doing it too. Only started in Icey weather, so maybe that's the key.
  9. Remove Advertisements
