DeVille oil change
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, DeVille oil change in Past Cadillac Vehicle Discussion; I'm thinking about doing my own oil changes, and would like to drain the pan while the car is on ...
    vettman is offline Cadillac Owners Member
    Automobile(s): 2002 DTS
    Apr 2004
    54
    DeVille oil change
    I'm thinking about doing my own oil changes, and would like to drain the pan while the car is on a set of "rhino ramps". My question is: will the pan/engine drain completely while the car is on the ramps, or does the car need to be level for draining? Thanks in advance to anyone that responds.
    Ranger is online now Cadillac Owners Member
    68
    81,887
    Re: DeVille oil change
    The drain plug is at the rear of the pan so it should drain just fine. Be carefull pulling on the ramps. The cowling is pretty low. I am not able to get mine on my ramps because of it.
    Apr 2004
    54
    Thanks for the reply, Ranger. FYI, I can drive my 2000 Vette up on the Rhino ramps with no problem. I don't think the DeVille is that low.
    JohnnyO's Avatar
    JohnnyO is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado, '04 DeVille
    Nov 2003
    Pittsburgh, PA
    194
    PostRe: DeVille oil change
    :coolgleam Yes, the plug is at the rear of the pan. FWIW, I've tried Mobil 1 filters once or twice (overkill, I know :rolleyes2 but if I didn't care I wouldn't be here) but they have more than one set of threads cut into them and can be a PITN to install. An AC will spin right on, costs less than half as much too.
  7. Remove Advertisements
