hi guys! First post here and I'm hoping you can help me out and I'll sure try to be of help in the community as well. I just bought a 1997 Cadillac Deville Concours. 114,000 miles on it. So far so good with how it runs and rides. I love it. However, Just yesterday I noticed that the blower motor quit working. If you adjust the temp to max cool or max heat... it does not blow ant full speed as it should. While driving down the road, you can feel the air coming out ok from the vent but not at a stop. I've also noticed that while you are driving down the road... the air you can feel seems way more prevalent on the passenger side of the vents VS the drivers side.
Here's what I know. The auto parking brake release still works fine. The electrical connection to the fan itself looks great. Beating on the fan with hammer is unproductive. Searched for other vacuum leaks but haven't really found anything. Hear a slight 'hiss' noise near the pass side fire wall that coninues for a little bit after you shut the engine off. This seems to be coming from the ac line going into the firewall but until this the AC did work very well. Blower motor has a three wire plug of which both power wires going into it do have power.
I'm hoping it's just a blower motor but a little worried about the whole more air on the pass side while headed down the road. I remember my mothers '96 Seville wouldn't blow heat on the passenger side... only blew on the drivers side. Not sure why but I'm hoping I don't have any issues here with that.
Like I said, everything worked perfectly the day before yesterday.
Any help or insight here will be VERY appreciated!
things I've done to the vehicle so far:
Mobile one oil change
air filter change
fuel filter change
oil pressure switch change (oil light was blinking now it's not.)
Again.... any help would be great!!! Thanks in avance!!!
