| Re: 89 DeVille Brake Booster Simply clamp off the hose to the booster with a pair of vise grips, does the idle lower? If not, the booster's OK. caliper slide pins rarely get cleaned and regreased in a driveway brake job. The pins will bind and not allow the caliper to slide back when the pedal's released. In rare cases I've seen restricted rubber brake hoses at the caliper which restrict fluid flow back when the pedal's released. Hard to verify the hose except to apply the brake, release the pedal and see if the rotor is hard to rotate. If it is, crack open the bleed screw, if it now spins easier, the hose is restricted. Remove each front caliper pin one at a time on BOTH sides, clean them on a wire brush, lube them and reinstall and I'll bet the problems fixed. |
