Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: As the cold weather does, so does the hesitation
11-04-09, 11:23 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1991 Sedan Deville | | Join Date: Mar 2009 Location: Winnipeg, MB Age: 18 | | | As the cold weather does, so does the hesitation Ok, so it hasn't stalled yet, but I'm sure that it will at some point when it gets colder. The car will bog from a stop when its cold, once you're going, there are no issues. It will also be fine after about 15 min of driving (no more bog). No codes, any idea what this could be? |
11-05-09, 10:04 AM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: As the cold weather does, so does the hesitation 4.9 pushrod engine, throttlebody injection, right ?? (Update your profile.....)
Sounds like the cold weather enrichment signal (the electronic "choke") is incorrect. Does your car have an ambient air temperature sensor somewhere near the front of the radiator and is it functioning? ..............maybe the intake air charge temp sensor....... |
11-05-09, 12:07 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1991 Sedan Deville | | Join Date: Mar 2009 Location: Winnipeg, MB Age: 18 | | | Re: As the cold weather does, so does the hesitation Quote:
Originally Posted by submariner409 4.9 pushrod engine, throttlebody injection, right ?? (Update your profile.....)
[i]. | Yes. Does that mean that its running to lean when its cold, then its at the right a/f when its warmed up? Not sure to the last question.... |
11-05-09, 12:16 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: As the cold weather does, so does the hesitation Wait a minute. Isn't the 4.9 multiport injected? |
11-05-09, 12:27 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1991 Sedan Deville | | Join Date: Mar 2009 Location: Winnipeg, MB Age: 18 | | | Re: As the cold weather does, so does the hesitation Whoops, just read pushrod. Yeah, its MPI. |
11-05-09, 03:51 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: As the cold weather does, so does the hesitation Either way, injector timing is changed to supply a richer mixture at cold starts and during the first phase of warmup. That enrichment function is controlled by the various temp sensors and MAF input to the ECM/PCM. |
11-05-09, 07:34 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1991 Sedan Deville | | Join Date: Mar 2009 Location: Winnipeg, MB Age: 18 | | | Re: As the cold weather does, so does the hesitation Yeah, I meant mine must be running lean, and then when the engine is warm it can run that leaner mixture w/o a problem but for the first little while it hesitates. So how many different sensors are there? |
11-05-09, 07:42 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: As the cold weather does, so does the hesitation For starters, the IAT (Intake Air Temp), the coolant temp, and maybe the ambient air temp is tied in there. One, two, or all three can combine to set fuel ratios along with the MAF. |
11-08-09, 03:17 PM
| | Cadillac Owners Fanatic Cadillac(s): 2004 DeVille, formerly 74 Fleetwood, 76 Eldo Conv. | | | | | Re: As the cold weather does, so does the hesitation My 04 Deville would run like it was congested for the first mile or two in cold weather. Turned out it was the parking brake not releasing fully. |
11-10-09, 12:59 PM
Originally Posted by ral1960 My 04 Deville would run like it was congested for the first mile or two in cold weather. Turned out it was the parking brake not releasing fully. | I know that my auto release is messed up, but I never set the parking brake, so it couldn't be that |
11-10-09, 01:21 PM
| | Cadillac Owners Enthusiast Cadillac(s): 1985 Sedan DeVille | | Join Date: Aug 2007 Location: Southern Maryland | | | Re: As the cold weather does, so does the hesitation EGR sticking |
11-10-09, 02:29 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1991 Sedan Deville | | Join Date: Mar 2009 Location: Winnipeg, MB Age: 18 | | | Re: As the cold weather does, so does the hesitation Had that checked. |
11-10-09, 03:01 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: As the cold weather does, so does the hesitation Is your parking brake release vacuum operated? If it is, and you have a vacuum leak in that system (not uncommon), then that's a distinct contributor to your hesitation. |
11-10-09, 06:01 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: As the cold weather does, so does the hesitation Yes, his brake release is vacuum operated. Probably a bad diaphragm. |
11-10-09, 06:09 PM
|  | Cadillac Owners Member Cadillac(s): 1992 Brougham | | Join Date: Mar 2009 Location: New Hampshire Age: 46 | | | Re: As the cold weather does, so does the hesitation Quote:
Originally Posted by V-Eight Ok, so it hasn't stalled yet, but I'm sure that it will at some point when it gets colder. The car will bog from a stop when its cold, once you're going, there are no issues. It will also be fine after about 15 min of driving (no more bog). No codes, any idea what this could be? | I hope this isn't silly or insulting in anyway. I am no where as technical as these others are, but my 92 Brougham starting doing that bog thing late sept early oct. I changed plugs, wires distrbtr/rotor. No more bogging. Just a thought and all I can contribute. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
