Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Replacing Both Front Wheel Bearings
11-02-09, 08:33 PM
| | Cadillac Owners Member Cadillac(s): '97 Cadillac Deville D'Elegance | | Join Date: Sep 2009 Age: 18 | | | Replacing Both Front Wheel Bearings Hey everybody,
So, plain and simple, I need to replace both front wheel bearings. I've done some research, and I understand it isn't a very hard job to do yourself. A local auto shop wants $800 to do it, and I am a broke college student, and can not afford to do that. However, I am an engineering major, and I get off on fixing things, so I'd like to do it myself, and save money.
Some things I need to know:
-Is it necessary to purchase a torque wrench? Does it need to be set at a certain tightness? and if so, how tight?
-I have the basics down for replacing wheel bearings, but is there anything specific I need to know about my model, or it being front wheel drive?
-What tools will I need? I have a basic tool set, but it's more like a house-hold tool set, and it's about the size of a briefcase.
....Any help would be greatly appreciated. |
11-02-09, 09:27 PM
| | Cadillac Owners Fanatic Cadillac(s): 1995 Deville 4.9L 190,000m | | Join Date: Jun 2009 Location: Douglasville, GA Age: 38 | | | Re: Replacing Both Front Wheel Bearings If you're going to do your own repairs, you'll need a torque wrench. |
11-02-09, 10:11 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Replacing Both Front Wheel Bearings And a 34mm socket. |
11-02-09, 10:19 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2000 Deville / 2002 Deville | | Join Date: Mar 2004 Location: Wilmington, NC Age: 44 | | | Re: Replacing Both Front Wheel Bearings It's a pretty straight forward job. You will need a torque wrench for the Hub Nut the torque value is 110 ft lbs. You should be able to borrow a torque wrench and the large socket for the Hub Nut from your local auto parts store. Both Auto Zone and Advance have a loan a tool program.
You may also need a puller to separate the hub from the axle if it's stuck. I didn't need one when I did my 2000 but, if you do they should also be available to borrow under the loan a tool program. http://www.autozone.com/autozone/ino...latLanding.jsp Hub.gif |
11-02-09, 11:00 PM
| | Cadillac Owners Member Cadillac(s): '97 Cadillac Deville D'Elegance | | Join Date: Sep 2009 Age: 18 | | | Re: Replacing Both Front Wheel Bearings Thanks a lot for the help man, I actually have a buddy with a torque wrench, and l've decided to invest in a decent tool box.
Do you really think it's necessary to get a puller? I mean, if it is stuck on there good, do you think it could be pryed off somehow w/out breaking anything? |
11-03-09, 08:37 AM
| | Cadillac Owners Fanatic Cadillac(s): 1995 Deville 4.9L 190,000m | | Join Date: Jun 2009 Location: Douglasville, GA Age: 38 | | | Re: Replacing Both Front Wheel Bearings Quote:
Originally Posted by washingtonnnn Do you really think it's necessary to get a puller? I mean, if it is stuck on there good, do you think it could be pryed off somehow w/out breaking anything? | Maybe, but the puller makes it really easy. |
11-03-09, 11:54 AM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Replacing Both Front Wheel Bearings If it is corroded in place, sometimes even a puller won't do it. Prying certainly won't. Have a friend hold the flat end of a ball peen hammer on the axle shaft. Now you get a big heavy mallet and give the ball end a good whack. That should sheer the bond. |
11-04-09, 02:39 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1990 Cadillac sedan devile | | Join Date: May 2008 Location: Milan IL USA Age: 27 | | | Re: Replacing Both Front Wheel Bearings A BFH always makes any job go faster. No tool in any toolbox can replace a 5lb sledge. LMAO |
11-04-09, 10:29 AM
Originally Posted by quins90lac A BFH always makes any job go faster. No tool in any toolbox can replace a 5lb sledge. LMAO | We used to joke around in the army motor pool that the perfect tool box contained a graduated set of hammers.  |
11-04-09, 11:15 AM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Replacing Both Front Wheel Bearings  ..................don't forget the Metric crescent wrench. |
11-04-09, 12:01 PM
Originally Posted by submariner409  ..................don't forget the Metric crescent wrench. | While you're looking for that, get me a can of squelch and a box of grid squares.  |
11-04-09, 12:04 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Replacing Both Front Wheel Bearings Mechanics credo. If it doesn't fit, get a bigger hammer. |
11-04-09, 04:18 PM
| | Cadillac Owners Member Cadillac(s): 1995 cadillac deville concours | | Join Date: Sep 2008 Location: Lockport IL Age: 21 | | | Re: Replacing Both Front Wheel Bearings i replaced both of mine last summer and il tell ya what! without the right tools its gonna suck! i believe on my deville the 3 bolts holding the hub in place were torx type fittings (i have no idea why gm tortures us with these odd ball sockets and such lol) as mentioned by the other gents in the thread getting the darn thing out is a PITA. i didnt have a puller ether. i used a method similar to rangers. when i finally removed it the stamped metal cap (i believe its blue in color) on the back of the old hub assembly broke off and got stuck. i just used a flat head screw driver and poked it out. |
11-08-09, 12:01 PM
| | Cadillac Owners Member Cadillac(s): 1998 Deville Base | | | | | Re: Replacing Both Front Wheel Bearings Not sure if you've already done this work, but I just performed the same repair on my '99 Deville. The three bolts are NOT torx bolts, they are regular 6 sided bolts. VERY IMPORTANT - you must use high quality sockets that are 6 point, not 12 point! I read up on this extensively on this site before doing the repair and I can say with absolute certainty that by using the 6 point sockets I had a much more secure fit than by using the 12 point setup. So in advance of the repair, I purchased two sockets (one deep and one normal) with the 6 point setup. Using them with various length extensions, I was able to remove the bolts without much trouble. You will absolutely want/need to torque these to spec after the repair is done. Good luck!
Andrew |
11-08-09, 05:03 PM
| | Cadillac Owners Member Cadillac(s): '97 Cadillac Deville D'Elegance | | Join Date: Sep 2009 Age: 18 | | | Re: Replacing Both Front Wheel Bearings I haven't started doing this yet, and thanks for the info., I wasn't looking forward to buying another set of sockets...although my '97 might be different from your '99, I'm not gonna buy them unless I find out I need them for sure.
Once you removed the brake rotor, how difficult was the rest of the job? Is there anything I should expect while doing the job? How tight did you torque the bolts to?
thanks, jake | | Cadillac Discussion Tools | | |
Censor is ON | | | |
