Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: Looking for a wiring diagram for 99 Deville
Old 10-29-09, 01:37 PM
Cadillac(s): 1999 Cadillac Deville
View dakid6945's Photo Album
Casino Cash: $700
Question Looking for a wiring diagram for 99 Deville
Looking for a wiring diagram for my 1999 Cadillac Deville. Need to find which wire is the speed sensor. Installing navigation in my car and I dont know which wire is the speed sensor. Any and all help would be greatly appreciated.
  #2 (permalink)
Old 10-29-09, 02:19 PM
dirt_cheap_fleetwood's Avatar
Redneck with class
Cadillac(s): 1990 350 Brougham (Its big), 1988 Mark VII LSC (Its fast)
View dirt_cheap_fleetwood's Photo Album
Casino Cash: $12635
Re: Looking for a wiring diagram for 99 Deville
Why do you need a speed sensor wire for Nav? What is wrong with a good 'ol TomTom suction cupped to the dash?
I sincerely hope you are not planning on replacing the factory head unit with an aftermarket one or that you plan on splicing into ANY sensor wires. You have no idea the shit storm that will be released upon you. These cars are very intertwined electrically, removing the factory radio will screw up more systems than you can imagine. Even worse is cutting or tapping into a sensor wire, where altering the signal by only a few millivolts can confuse the hell out of the computer and make the car run like crap or not run at all. They are so sensitive that you cannot even solder a wire together if it breaks because the solder causes excessive resistance, the entire wire must be replaced.
"I treasure my remark to my grandson who asked, 'Grandpa, were you a hero in the war?' Grandpa said, 'No... but I served in a company of heroes.'" Sgt. Mike Ranney, quoted by Maj. Richard Winters
  #3 (permalink)
Old 10-29-09, 02:49 PM
submariner409's Avatar
Casino Cash: $20719
Unless you know exactly what you are doing and have the proper jumpers and harnesses, you're gonna open a Pandora's Box that will never close.
  #4 (permalink)
Old 10-29-09, 03:27 PM
Casino Cash: $700
i have already replaced my factory hu and alarm system. both have been in my deville since june without any issues. i appreciate the warnings as well. with that being said, can anyone advise of the color and location of the speed sensor wire?
  #5 (permalink)
Old 10-29-09, 08:16 PM
Redneck with class
Casino Cash: $12635
It still begs the question, why do you need the speed sensor wire for a nav unit? It has GPS, it should already know how fast you are going. I will look up the info you need at school tomorrow.
  #6 (permalink)
Old 10-30-09, 07:49 AM
Casino Cash: $700
"By using a high sensitivity 12-channel GPS receiver, an on-board gyroscope and connecting to the vehicle’s speed sense circuit, the NAX980HD to functions just like a factory installed navigation system. It knows where you are, which way you are going, and actually learns your driving habits to get you where you want to go like no other system."
http://clarion.com/us/en/products/20...408777755.html
This is why I need the wire and location. I was told that it was a dark green and white wire located in the instrument cluster. Looking to verify if this is correct.
  #7 (permalink)
Old 10-30-09, 07:52 AM
Casino Cash: $700
Thank you in advance for your warnings, advice, and help!!!!
  #8 (permalink)
Old 10-30-09, 08:50 AM
Dave S Texas's Avatar
Cadillac Owners Enthusiast
Cadillac(s): '87 Coupe DeVille 4.1L FWD(New engine Dec '08)
View Dave S Texas's Photo Album
Casino Cash: $9645
FWIW.....A Factory Service Manual has all the info you will ever need when working on your DeVille. Look at ebay item #250521101023. Best tool you can have at your disposal.
  #9 (permalink)
Old 10-30-09, 07:05 PM
Cadillac(s): 2000 SLS
View Eric's Photo Album
Casino Cash: $5869
FSM shows Vehicle Speed Signal is DK GRN/WHT wire in Pin K of Cruise Control Connector which is located at the left rear of the engine compartment, on the left strut tower.
  #10 (permalink)
Old 10-30-09, 07:44 PM
Mark C's Avatar
Cadillac(s): 1997 Seville STS, 2000 Seville STS
View Mark C's Photo Album
Casino Cash: $16495
Its also a darkgreen/white wire on pin B5 of the C1 Instrument Panel Connector, circuit 817. Its a 24 pin connector looking at the connector from the mating end the A terminals are closest to the side of the connector with the latch on it, B's are on the side furthest from the latch, the 1 terminalss (A1/B1) are to the left side, and the 12s (A12/B12). The instrument cluster has 2 24 pin connectors (C1 and C2) and one 64 pin connector (C3) on the top rear of the cluster. C1 is the one with the orange power wire in the A1 position (latch side left end) C2 (not the one you want) has a light blue wire in that location.
The dark green/white wire runs from C1 B5 to C205 terminal P(Body harness to the engine harness, under the right side of the IP, near the IP compartment) then out into the engine compartment thru penetration P100 (On the right rear of the engine compartment, near the strut tower) to connector C2 pin 25 on the PCM. The cruise control feed taps off pin P in C205 goes thru penetration P100 over to terminal K on the cruise control module in the engine compartment, and also to connector C2 terminal C6 on the CVRSS module inside the car(if you have one).
Tags: , , , ,
deville, diagram, wiring
