I guess they changed it a little since I did my '97. The screens where side by side. The side cover is over the drivers side fender on the end of the trans. It is where the filler cap is. You can't see it from below. You'll be under it. The plug is just a bolt and will be below that side cover. You should have gotten very little fluid out of the pan. Just pull what ever bolt you think it is. If no fluid drains, it's the wrong one. Torque it back down and try another.
I paid a tech on just answer and he stated there is no drain plug, once you drop the pan that's it?
Hope you didn't pay to much for that bum info.
