Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Need help finding OEM spark plugs
10-20-09, 09:18 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Need help finding OEM spark plugs 2001 Cadillac Deville DHS
Which plug should I use? 41987, 41929 or even 41-937? Does anyone have my car, and if so which did/do you have?
All Listed plugs have a gap of 0.050
Autozone – AC Delco 41-987
Kragen – AC Delco 41987
Alldata.com - AC Type 41-929 (Cannot find plug)
GM Service Information - Document ID# 507608 lists Nipendenso Type 12561466 Gap: 1.27 mm (0.050 inch) When I cross reference 12561466 Rock Auto lists them as 41-987
Local Dealer – 12571535. When this is cross referenced this Rock Auto lists them as 41-987
Haynes Manual – AC 41-937 – I know someone said not to use the Haynes
but this was actually my last check as I was curious.
Can I not buy OE plugs or is this it? If these fit, why would so many different part numbers (and different plug specifications?) come back to 41-987? I am still concerned about the 41929 from alldata.com. Granted it is only one issue, but it’s one of 6 things I’ve researched on the site. And, the only part I’ve looked up so far. The information is still valuable, but should I trust their listed part #’s? Has anyone else had this problem? Not trying to be anal, it’s just a little odd to me. |
10-20-09, 10:24 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2000 Deville / 2002 Deville | | Join Date: Mar 2004 Location: Wilmington, NC Age: 44 | | | Re: Need help finding OEM spark plugs The only plugs you should use in your N* are the AC Delco 41-987 they come pre-gapped to .050. Any other plug will cause mis-fires. |
10-20-09, 10:29 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Need help finding OEM spark plugs Yup. 2000+ Northstar uses A/C Delco 41-987. |
10-21-09, 09:21 AM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Need help finding OEM spark plugs AC Delco #41-987. RockAuto generally has a decent price. Torque each to 13 ft/lb. Here's what you'll be looking at............... |
10-21-09, 06:46 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: Need help finding OEM spark plugs Good Deal. Has anybody had issues with wrong part numbers from alldata? I'd like to order a replacement radiator, and have it when I take the existing one out. Downside, cannot measure it and I am not 100% positive mine has an oil cooler line.
Is the model number accessible without taking radiator out? If so, any ideas on it's location? |
10-21-09, 06:49 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2003 Cadillac Deville, 2006 DTS, 2008 Saturn Vue XR | | Join Date: Sep 2008 Location: Ontario, Canada Age: 41 | | | Re: Need help finding OEM spark plugs Quote:
Originally Posted by 00 Deville The only plugs you should use in your N* are the AC Delco 41-987 they come pre-gapped to .050. Any other plug will cause mis-fires. | Not true, I use NGK and never had any misfires or rough idling. NGK supplies alot of plugs to car manufacturer's including GM. My mechanic swears by them and has never had any problems. Just make sure you use the platinum for your Northstar engine. |
10-21-09, 07:41 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2000 Deville / 2002 Deville | | Join Date: Mar 2004 Location: Wilmington, NC Age: 44 | | | Re: Need help finding OEM spark plugs Quote:
Originally Posted by DevilleDeeman Not true, I use NGK and never had any misfires or rough idling. NGK supplies alot of plugs to car manufacturer's including GM. My mechanic swears by them and has never had any problems. Just make sure you use the platinum for your Northstar engine. | You need to keep your fingers crossed...
There have been a lot of people on this forum that have had misfire issues with the NGK's. They are a lot cheaper than the OEM plugs. A lot of shops will use the cheaper plugs so they can mark them up more without the customer raising hell.
You really ought to learn how to change your own plugs... it's not that hard. |
10-21-09, 07:41 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Need help finding OEM spark plugs Oil cooler lines (2) run from the oil filter adapter top case to the front of the radiator passenger side tank.
Look at the list of RPO (Regular Production Option) codes under the spare tire cover and enter all the 3-letter codes into www.cadillacfaq.com/rpo/index.php. You're looking for an RPO that specifies heavy duty cooling or a towing package. Chances are, if you don't have that, you don't have an oil cooler.
The cooler lines attach, with spring locked quick-connects, to the fittings shown. In response to a question, this post refers to Post #5. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
