Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Any help or advice will be greatly appreciated!!
10-17-09, 08:23 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Any help or advice will be greatly appreciated!! I would have guess 2000, but here is proof positive. Don't think my daughters '02 has a rattler.
Was that the "River Runs Through It" thread? |
10-17-09, 10:40 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: Any help or advice will be greatly appreciated!! During a 10 minute drive through town, quick stint on freeway (1-2 miles), my DIC started to display "Engine Hot - AC Off" Any ideas? Not too long ago when the gauge got hot, I could turn on the heater and it would go back down, now it just blows cold air. If I punch the gas, then the air gets hot and temp starts to go back down. All this after trying to do routine maintenance on cooling system. |
10-17-09, 10:43 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Any help or advice will be greatly appreciated!! I suspect you may have air in the system. |
10-17-09, 10:46 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: Any help or advice will be greatly appreciated!! is it possible to check timing on this car? Everywhere I read states check timing but, the Haynes guide section on checking timing says it's only applicable on the 4.9 engines. |
10-17-09, 10:50 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: Any help or advice will be greatly appreciated!! Quote:
Originally Posted by Ranger I suspect you may have air in the system. | to fix this I assume I need to simply take off the reservoir cap, start the car and let it run until I see it burp or the level drop? What if these things occur and are not noticeable? What is an acceptable amount of time to continue this process, if correct? |
10-17-09, 10:52 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: Any help or advice will be greatly appreciated!! By the way, thanks for all of the help and feedback! |
10-17-09, 10:54 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Any help or advice will be greatly appreciated!! You should have to do nothing. The system is self purging. I changed y coolant a few months ago and had to top it off 3 times before all the air got purged. Might check the purge line to be sure it is clear and flows coolant. |
10-18-09, 12:17 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Any help or advice will be greatly appreciated!! No way to "check" timing. It's all electronic with absolutely no adjustments.
Get rid of the Haynes, get on eBay and find a Helm/GM shop manual or subscribe your car to www.alldatadiy.com. Haynes is far too generic for your car: the 4.9 went out 6 years before your car was built......... |
10-18-09, 10:08 PM
Originally Posted by submariner409 | Will do. Especially considering the company is local. Did not know that. |
10-20-09, 01:07 AM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: Any help or advice will be greatly appreciated!! Hey...If anyone is still around. Could someone point me in the direction of the intake manifold vacuum port? |
10-20-09, 04:17 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Any help or advice will be greatly appreciated!! For what? The PCV? On the '03 it is behind the P/S pump. I could not even see it. Just the line that runs back in there so there must be a port there. |
10-20-09, 08:22 PM
Originally Posted by Ranger For what? The PCV? On the '03 it is behind the P/S pump. I could not even see it. Just the line that runs back in there so there must be a port there. | I bought a compression/vacuum kit and need to hook it up. While I do know about different aspects of car maintenance and care, I am not that familiar with technical terminology. |
10-20-09, 09:27 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: Any help or advice will be greatly appreciated!! I just ordered a maf, hope it takes care of the power issues. I'll post the results later. Is there anyway to check the radiator for blockages? The car gets hot, but when given more power, it goes down a little. The heater does not get hot when this happens either. But, after giving the car some gas, the heater will kick back on for a minute or so. Then, we'll repeat the process. |
10-20-09, 10:31 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Any help or advice will be greatly appreciated!! Check the purge line for coolant flow.
Not sure what a compression/vacuum kit is. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
