Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: 2000 Deville DHS Check Coolant Level message
Old 10-08-09, 12:23 PM
Cadillac(s): DHS
View PhilV's Photo Album
Casino Cash: $335
Red face 2000 Deville DHS Check Coolant Level message
Right after I had the coolant drained and replaced I began getting the 'Check Coolant Level' message right after start-up every time. I topped off with additional coolant with no change to the message. Seems like a possible bad sensor? I have 128k miles on the old buggy, but running well otherwise. The temp goes to and stays steady on 12 o'clock on the gage. Would replacing the sensor be the best move - or is there a way to disable the sensor by shorting the wires as I seen mentioned on other models. Also, is there an overflow tank - and where is it? I haven't had any luck locating one.
Thanks in advance,
PhilV
  #2 (permalink)
Old 10-08-09, 01:08 PM
View Ranger's Photo Album
Casino Cash: $24166
Re: 2000 Deville DHS Check Coolant Level message
No "overflow" tank, only the surge tank. Can't change the sensor. You'll have to change the tank. I think you can unplug the sensor from below the tank and connect the wires, but of coarse you'll loose the early warning.
  #3 (permalink)
Old 10-08-09, 01:23 PM
DevilleDeeman's Avatar
Cadillac(s): 2003 Cadillac Deville, 2006 DTS, 2008 Saturn Vue XR
View DevilleDeeman's Photo Album
Casino Cash: $915
check the sensor at the bottom of the surge tank, the connection can get dirty...thats what happened to my '03 once. If the connection is ok, do what Ranger said replace the tank. Did you try clearing the code? Does it keep coming back?
  #4 (permalink)
Old 10-08-09, 02:34 PM
Cadillac(s): 01 DTS
View CarCzar313's Photo Album
Casino Cash: $1085
same thing happened to my 01 DTS after a flush/fill. Tank was full. Ran and cleared codes and it never came back. Temp gage reads high noon also.
  #5 (permalink)
Old 10-08-09, 03:00 PM
submariner409's Avatar
Casino Cash: $20619
Maintain that surge tank at half full, cold. No higher.
The surge tank is the modern equivalent of the airspace in the top tank of an old downflow radiator: you must provide room for coolant expansion and contraction. No space and expanding coolant blows out of the cap pressure relief.
  #6 (permalink)
Old 10-08-09, 04:56 PM
Cadillac(s): DHS
Casino Cash: $335
I've been clearing the code with the Info Reset button on the dash daily. I guess I should clear them with the code reader? I'll have a look at the connector on the bottom too, and recheck the fill level.
Thanks so far...
  #7 (permalink)
Old 10-08-09, 05:47 PM
Casino Cash: $24166
Thanks so far...
No need for a code reader if you are clearing them correctly via the DIC.
  #8 (permalink)
Old 10-08-09, 06:54 PM
Casino Cash: $20619
Sounds like he's turning off a DIC message with INFO RESET. Maybe hasn't read the sticky ^^^ "How to pull codes" because he also refers to an aftermarket code scanner.
It's already all built into the car...............
  #9 (permalink)
Old 10-08-09, 08:01 PM
Cadillac(s): '98 STS
View JimD's Photo Album
Casino Cash: $18483
Thanks so far...
I think this issue has been unnecessarily complicated by a terminology problem.
Your CHECK COOLANT LEVEL is only a "message". It's information only and comparable to the ICE POSSIBLE message you might see. There are no "codes" associated with these "messages".
  #10 (permalink)
Old 10-08-09, 08:25 PM
Casino Cash: $20619
You're so darn practical.....
  #11 (permalink)
Old 10-30-09, 06:13 PM
Cadillac(s): 2004 deville
View arifleman's Photo Album
Casino Cash: $385
I had a similar situation when changing coolant - recurring check coolant code, even though it was filled right to midlevel mark when cold. I stuck a long screwdriver shaft in the recovery bottle and tried to jiggle the sensor in the bottom of the tank. I also rapped the outside of the tank, where the sensor sits, with the handle of that screwdriver. One of those techniques worked. YMMV. Good luck all.
  #12 (permalink)
Old 10-30-09, 08:10 PM
Mark C's Avatar
Cadillac(s): 1997 Seville STS, 2000 Seville STS
View Mark C's Photo Album
Casino Cash: $16395
Happened to my Seville when I drained and replaced the antifreeze recently. I think when the coolant sealing tabs disolve some of it collects in bottom of the cylinder that the float switch in the surge tank travels up and down in and when you drain the system the float gets stuck in the gunk at the bottom of the shaft. After a couple of days and a few taps on the side of the tank, the float got freed up and everything is fine.
  #13 (permalink)
Old 11-14-09, 06:24 AM
Cadillac(s): 2000 Deville
View Marco's Photo Album
Casino Cash: $1515
Just received my new coolant recovery tank for my 2000 Deville from rockauto.
I'm replacing mine due to the plastic nipple developing a hairline crack/leak where the hose clamps onto the tank.
Figured I'd flush the system while I'm at it and refill with dexcool 50/50 by prestone.
Any danger in doing that? or do I need to buy the ac delco brand?
Also, what about the tablets? Is that still recommended for the 2000 base model?
  #14 (permalink)
Old 11-14-09, 10:36 AM
Casino Cash: $20619
Prestone's DEX-COOL is perfectly OK. Don't get crazy with extended flushing or chemicals. Just drain as much as you can (2 - 3 quarts will remain in the block as there are no block drains) and refill with a proper mix of DEX-COOL and distilled water (supermarket). GM has pretty much discontinued the use of the Bar's tablets (or the powder, G12BP), so if you had no leaks before you started, there's no reason to use them now. IF you run clear water through the system and then drain it, mix your coolant at about 60/40 coolant to distilled water to account for the water still in the block and elsewhere.
  #15 (permalink)
Old 11-15-09, 03:28 PM
Cadillac(s): 2000 DTS & 2001 STS
View caddi2323's Photo Album
Casino Cash: $370
I have the same message on my 2000 DTS. I have no idea how you go about using a long screw driver to push the floating sensor down and up because a little after the spout where you pour the coolant in, there is a screen type filter so you can't push a long screw driver down.
Do you stick the screw driver in side ways to get to the side of the reservoir?
Where is the sensor plug?
Is this method possible with my model here are a few pictures?
Tags: , , ,
2000, check, coolant, deville, dhs, level, message
