Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: oil pressure light
  #16 (permalink)
Old 10-10-09, 07:45 PM
View Ranger's Photo Album
Casino Cash: $24266
Re: oil pressure light
I hate to admit it, but I actually used that crap when I was younger and more gullible.
  #17 (permalink)
Old 10-11-09, 11:41 AM
Cadillac(s): 1995 Deville 4.9L 190,000m
View Freakzilla's Photo Album
Casino Cash: $1755
Originally Posted by fatngs View Post
i replaced the oil sending unit; right after, about 15 min after driving it did it again only the oil light would come on at anything under 1000 rpm
i was on my way to a doctor's appointment so i had to keep going; i pretty much braked with my left foot and kept my right foot on the gas to keep the revs up
however, on the way back it was fine and havent had the problem since
also i havent changed the oil yet
Mine did the same thing. It came on once after changing then never again.
  #18 (permalink)
Old 11-05-09, 10:08 AM
Casino Cash: $1755
Now it's back.
I had my transmission rebuilt, and when I drove it home, the "Low Oil Pressure" warning chimed constantly.
Back story:
When this problem originally started, my oil was low when the warning came on. From then on it only came on when idling in drive.
I changed the oil pump and bought a new sensor from Napa, but it was the wrong size so I put the old one back on. The warning never came back, until I picked it up after having the tranny rebuilt.
I bought a sensor at Autozone and when replacing I noticed water between the pigtail connector and the sensor. I guess the transmission place pressure washed it.
I cleaned out the pigtail connector with quick dry electronics cleaner and replaced the switch. No message until a day later.
I changed the oil and put 5W-30, is that too light? Light enough to cause the warning?
I plan on trying a Napa sensor to see if that makes a difference...
  #19 (permalink)
Old 11-05-09, 10:17 AM
submariner409's Avatar
Casino Cash: $20719
I believe your engine is spec'd for 10W-30 oil, year 'round. If it's not too much of a hassle, change the oil again and use a WIX filter.
5W-30 may well give you an idle speed oil light when hot.
  #20 (permalink)
Old 11-05-09, 11:44 AM
Casino Cash: $1755
When putting the filler cap back on (of course) I noticed it said 10W-30. So I checked in the Hayse manual and it said you could use 5W-30 in cold weather. However, it doesn't get THAT cold in Atlanta.
WIX filter?
I've got a Bosch Premium filter on there now.
  #21 (permalink)
Old 11-05-09, 01:13 PM
Casino Cash: $1755
OK, Wix is a brand of filter. I see O'Reily's carries them. I've never tried them before. Better?
  #22 (permalink)
Old 11-05-09, 04:02 PM
Casino Cash: $20719
Go to http://minimopar.knizefamily.net/oilfilters/index.html and http://minimopar.knizefamily.net/oil.../opinions.html to form your own opinion on oil filter use. Also read http://www.carbibles.com/engineoil_bible.html
I now use WIX for most applications, but for many years I used Purolator.
  #23 (permalink)
Old 11-06-09, 09:45 AM
Casino Cash: $1755
I haven't changed anything yet but I'm starting to think I might have a bad wire somewhere.
The warning seems to come and go completely randomly. Like yesterday, I came to a stop on the interstate and it came on. Then once off the interstate I stopped at two red lights and it didn't.
  #24 (permalink)
Old 11-15-09, 09:43 PM
Casino Cash: $1755
I put 10W30 in and cleaned out the connection again.
I tightened up the sensor, it was showing a little thread still, could that make a difference?
  #25 (permalink)
Old 11-15-09, 09:53 PM
Casino Cash: $20719
No, the number of threads showing has no bearing on sensed pressure: The pressure in a hydraulic system (your engine oil pressure system is one) is equal at all points in the system: oil is incompressible. Flow rates differ according to clearances, but pressure is constant throughout the system.
  #26 (permalink)
Old 11-15-09, 10:50 PM
Casino Cash: $1755
That's what I figured.
Something else I noticed and just remembered... while cleaning the pigtail connector, I noticed one of the contacts was kind of brownish in color while the other two were silver (aluminium?) colored. Could the water in there have corroded that contact or something? That pigtail connector is $25!
The low pressure message hasn't come on since I changed the oil and cleaned the sensor but I only drove it about 6 miles to the Kroger and back. I'll find out for sure tomorrow.
  #27 (permalink)
Old 11-17-09, 03:00 PM
Casino Cash: $1755
I found this info in the FSM and there's some things I don't understand...
DESCRIPTION
This oil pressure indicating system incorporates an instrument voltage regulator, electrical oil pressure gauge and a sending unit which are connected in series. The sending unit consists of a diaphragm, contact and a variable resistor.
OPERATION
As oil pressure increases or decreases, the diaphragm actuated the contact on the variable resistor, in turn controlling current flow through the gauge. When oil pressure is low, the resistance of the variable resistor is high, restricting current flow to the gauge, in turn indicating low oil pressure. As oil pressure increases, the resistance of the variable resistor is lowered, permitting an increased current flow to the gauge, resulting in an increased gauge reading.
Service and Repair
Disconnect the oil pressure gauge lead from the sending unit, connect a 12 volt test lamp between the gauge lead and the ground and turn ignition on. If test lamp flashes, the instrument voltage regulator is functioning properly and the gauge circuit is not broken. If the test lamp remains lit, the instrument voltage regulator is defective and must be replaced. If the test lamp does not light, check the instrument voltage regulator for proper ground or an open circuit. Also, check for an open in the instrument voltage regulator to oil pressure gauge wire or in the gauge itself. If test lamp flashes and gauge is not accurate, the gauge may be out of calibration, requiring replacement.
1. Where is the instrument voltage regulator?
2. Where is the electrical oil pressure gauge?
Hopefully I'm going to have a little time to work on this on the weekend.
I've got a mechanical oil pressure guage I'm going to hook up and see what the actual pressure is first.
(11 psi at idle, 53 psi at 2,000 rmp per the FSM)
I'm not sure how I could run the mechanical oil pressure guage oil line into the cabin, any suggestions? I guess I could just crack the window.
But since the warning only comes on at idle, couldn't I just test it in the driveway?
  #28 (permalink)
Old 11-23-09, 08:24 AM
Casino Cash: $1755
I put in an AC Delco part from the Caddy dealer.
Fixed.
  #29 (permalink)
Old 11-24-09, 08:59 AM
Casino Cash: $1755
Fixed.
BETTER, but not fixed.
It doesn't go off in park now. I think I'll step the oil up a weight to 15W40.
  #30 (permalink)
Unread 11-25-09, 09:29 AM
Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville
View cadillac_al's Photo Album
Casino Cash: $10185
When I got a good deal on some 5-30 synthetic and put it in my old old 4.9, the oil light started coming on at idle. I immediately changed it to 15-40 since spring was coming soon and the oil light never came on again. I wouldn't run 15-40 if the temps get below 0 degrees though. Just my $.02.
Tags: , ,
light, oil, pressure
