Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Onstar (VCIM) removal on 2002 Deville
09-11-09, 02:57 PM
| | Cadillac Owners Member Cadillac(s): 2002 deville | | | | | Onstar (VCIM) removal on 2002 Deville I have a 2002 Cadillac Deville. I would like to disconnect/remove the VCIM Onstar module in my car. However, I do not know the location of it and how to disconnect/remove. Any help on this subject would be appreciated. Thanks. |
09-11-09, 03:24 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2000 Deville / 2002 Deville | | Join Date: Mar 2004 Location: Wilmington, NC Age: 44 | | | Re: Onstar (VCIM) removal on 2002 Deville The VCIM is located behind the rear seat back. Why do you want to remove it? Mine is still hooked up I have heard that disconnecting it will throw nuisance codes. |
09-11-09, 10:39 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Onstar (VCIM) removal on 2002 Deville If it is an analog setup (and I am sure it is) it won't work on today's cellular networks anyway.
The module is behind the rear seat back and to access the connections you have to do one of two things, remove the "electronics bay" panel in the trunk or remove the seat back itself.
Both can be tricky and sometimes you have to remove the seat back anyway to get the panel off.
Which one do you want to do and I'll give you some pointers.
Other modules will set codes once the VCIM is gone but as long as you know it you won't have much to worry about.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
09-14-09, 02:37 PM
| | Cadillac Owners Member Cadillac(s): 2002 deville | | | | | Re: Onstar (VCIM) removal on 2002 Deville Thanks for the information. Let me know which method of accessing the module is either. It's my understanding there are three cables I can disconnect from the module to disable it. You indicated there were some error messages relayed to the other modules. Those won't impact the car's operation, correct? I assume those error messages are only for diagnostic and troubleshooting purposes if hooked up to a computer. |
09-14-09, 04:21 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Onstar (VCIM) removal on 2002 Deville I would try going in from the trunk first.
Remove the carpet panel in the trunk that covers the seat back, you'll find three 10mm nuts. One at the top left, one left of center in a recess at the bottom and one way over to the right by the hinge.
If they start to spin and spin then you'll have to go inside and remove the seat back.
Once loose you can lean the panel back and reach over to disconnect things as necessary for access.
From there the VCIM is located towards the right hand outboard edge, it is a large module. There is actually one main connection at the bottom of the panel that you can undo that I believe all the VCIM wiring goes through.
The antennas won't matter but you can unhook them from the module.
The codes will be for lost communication and the modules will adapt, it should cause no other problems. |
09-14-09, 06:29 PM
| | Cadillac Owners Member Cadillac(s): 2002 deville | | | | | Re: Onstar (VCIM) removal on 2002 Deville Appreciate all of your advice and assistance. I will give it a try this weekend and let you know if I have any troubles. |
09-14-09, 07:19 PM
|  | Cadillac Owners Fanatic Cadillac(s): White Diamond '03 DTS | | Join Date: Feb 2007 Location: Elgin, IL | | | Re: Onstar (VCIM) removal on 2002 Deville Quote:
The codes will be for lost communication and the modules will adapt, it should cause no other problems. | For what it's worth, this is what I did some time ago and the dealer was kind enough to "remove" the phone option with their scan tool so that I get no messages. |
09-15-09, 03:47 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2003 Cadillac Deville, 2006 DTS, 2008 Saturn Vue XR | | Join Date: Sep 2008 Location: Ontario, Canada Age: 41 | | | Re: Onstar (VCIM) removal on 2002 Deville Why don't you just remove the two parts(stuck on with adhesive) on the rear glass and stick the cable under the headliner. That's what I did...out of sight, out of mind. |
09-15-09, 06:33 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Onstar (VCIM) removal on 2002 Deville Removing the antenna would be effective but I think he wants to do more. |
09-17-09, 01:09 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: Onstar (VCIM) removal on 2002 Deville I read this quote on another forum...
"They have millions of cars with the system activated. Nobody has time to worry about what you are doing and you're probably not important enough to get them interested."
Not being judgemental, but I'm inclined to agree.  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
