Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: 02 DTS shakes around 60mph to 75mph
  #31 (permalink)
Old 08-28-09, 02:27 PM
Cadillac(s): 2002 Deville
View Qball Customs's Photo Album
Casino Cash: $2830
Re: 02 DTS shakes around 60mph to 75mph
Originally Posted by brendanw View Post
Can you tell us more about the 'center rings' that you've mentioned? Maybe a source or a link?
Thanks!
I purchased them here. http://www.goodroads.net/
  #32 (permalink)
Old 08-28-09, 03:38 PM
View Ranger's Photo Album
Casino Cash: $24266
they are just putting in a new center console and its done.
Why did you replace it?
  #33 (permalink)
Old 08-28-09, 03:42 PM
DonRSD's Avatar
Cadillac(s): 2002 Deville DTS
View DonRSD's Photo Album
Casino Cash: $715
Originally Posted by DonRSD View Post
well i get the caddy back today!!!
they fixed everything.....so they say.....and i will see
as far as my shakes, the head mechanic told em they swapped out 2 rims and now the car doesnt shake between 60-80mph. when i get the car i will post back if this is indeed true.
well come to find out i will NOT be getting the caddy back today.
when the caddy dealer took the car out for the final test drive, they noticed some sound from the right front tire.
come to find out they are putting a new RIGHT FRONT STRUT BEARING & SEAT....whatever the heck that is
so monday = when the caddy returns to me.
i told him 'as long as everything is fixed, i dont mind waiting a few more days'
the armrest latch broke off on me when i was getting something from the arm rest compartment and since where the latch screws into the underneath of the armrest, they had to buy an entire new armrest
hey its FREE & ITS BRAND NEW NOW!!!!
  #34 (permalink)
Old 08-28-09, 03:49 PM
Casino Cash: $24266
That latch can probably be repaired. If you have the console with shifter, I might know someone interested if it is the right color.
  #35 (permalink)
Old 08-28-09, 05:05 PM
submariner409's Avatar
Casino Cash: $20719
In regard to the posts on "centering rings", the majority of this series of Cadillac OEM wheels center on the machined wheel bore and hub spigot, not on the bolt circle. Most aftermarket generic wheels rely on only the bolt circle to center the wheel. If the aftermarket wheel does not have the Cadillac 115mm bolt circle, but has the more common 114.3mm circle, it usually winds up a tad off center because the first lug nut to get tightened pulls the wheel onto that stud first, then the other studs bend to accommodate the induced misalignment, with the attendant out-of-round wheel tramp. Centering rings align the wheel on the hub spigot and force all the studs to bend into alignment with the (improper) 114.3mm bolt circle.
Look at the center of this 2003 CTS wheel and you can see the hub bore. (Not the center cap bore - the larger inner bore.) (I picked up a set of 4 for $100 - they're mounted with my late night rural road screamer tires.)
  #36 (permalink)
Old 08-29-09, 01:28 PM
DonRSD's Avatar
Casino Cash: $715
yes i have a shifter in the middle....its a DTS
my interior = cream color
i wish i had the dts for this weekend....i really miss it and hate driving the little 2006 cts.
  #37 (permalink)
Old 08-30-09, 12:50 PM
Casino Cash: $24266
You might try to PM ld00deville. I think he may be looking for a console. Not sure what color he needs though. He hasn't been here since 7/29 so I'm not sure if or when he will respond, but might be worth a try. Might work out for both of you.
  #38 (permalink)
Old 09-01-09, 01:17 PM
DonRSD's Avatar
Casino Cash: $715
i finally got the caddy back!!!!
the shakes are gone!!!
they replaced TWO rims with stock vehicle rims (same dts model & rim) as (per the report) the rims were 'out of round'
they also rebalanced all 4 tires
as far as the car shaking the head bolts were leaking so they replaced those and the entire head gasket......no more startup shaking
they also replaced all the engine mounts in this process
i cant believe the shimmy/vibration is gone......like i said 2 new rims did the job....i still have the same tires.
i take the highway there and back and i had the caddy everywhere from 50mph in traffic to 105mph in the open and NO SHIMMY/VIBRATION!!!!
the only thing i still notice is the car shifts kinda ;hard; from 1st to 2nd at low rpm's yet every other shift or a high 1st to 2nd shift is flawless.
any suggestions there?
i have the report here from the caddy dealer if anyone wants me to scan it to use for your future reference (ill edit out all my personal info of course )
Tags: , , , ,
60mph, 75mph, dts, shakes
