1998 Deville - change spark plugs
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1998 Deville - change spark plugs in Past Cadillac Vehicle Discussion; I want to change the spark plugs and wires. I am unable to get off the plastic cover on top ...
    dongill is offline Cadillac Owners Member
    May 2006
    Smile1998 Deville - change spark plugs
    I want to change the spark plugs and wires. I am unable to get off the plastic cover on top of the engine. There are four nuts holding the cover. Two nuts rotate but do not come loose. I think the bolts are rotating. Any suggestions? I appreciate any help you can give!
    68
    82,070
    Re: 1998 Cadillac Deville - change spark plugs
    Keep turning and pull the studs with it. Once they are off you can remove the studs, put them back and apply some anti-seize to the threads.
    mavric240's Avatar
    mavric240 is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville
    Mar 2014
    Dayton Ohio
    44
    180
    The padding under the cover can over time adhere to the plenum too so you might have to "gently tug" to get it loose.
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,651
    Make sure to put ground under the ICM over back plugs when you reinstall. It geta left off a lot.
  7. Remove Advertisements
