NEED HELP!!!!!! with 1991 deville - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, NEED HELP!!!!!! with 1991 deville in Past Cadillac Vehicle Discussion; yes he bleeded it before putting it in...
  1. #31
    defflepp1 is offline Cadillac Owners Member
    Automobile(s): NONE
    Jul 2009
    cedar rapids, IA
    23
    37
    Re: NEED HELP!!!!!! with 1991 deville
  2. #32
    68
    82,076
    Well, I don't know what to tell you, other than from your description, there is air in the lines.
  3. #33
    Automobile(s): NONE
    Jul 2009
    cedar rapids, IA
    23
    37
    yeah well thanks anyway
  5. #34
    Automobile(s): NONE
    Jul 2009
    cedar rapids, IA
    23
    37
    ok so now that is getting colder out the transmission problem is coming back. the best way i can describe it is, i will be driving and it dose not want to shift when it should. i can compare it to if i would give it full throttle and it would shift like at the red line but it's not even close to full throttle. there is also a new that may have something to do with it.
    (E090) ......... VCC/TCC Brake Switch/Park/neutral switch Input Circuit Problem
    if any one has any idea of what could be causing this problem they would be greatly appreciated
  6. #35
    calvin ar is offline Cadillac Owners Fanatic
    Automobile(s): 1991 devill
    Sep 2012
    35
    116
    sounds like you have a bad engine control computer(too mutch to be going bad all at once)
    $100 at rock auto for install get Henes manual
    could have happened if took positive side of battery off first (will frie them fast that way)
    could have also blown a fuse 3 fuse boxes in car hidden one under the glove box gets missed a lot.
  7. #36
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    This thread is 3 years old, and you won't damage the PCM by removing the positive battery cable before the negative.
    In any case,
  8. #37
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,486
    this post is 3 years old -
    don't get upset if they don't THANK you for the tip -
    MC - DAMN - you're quick -
    how did those fat fingers beat me to the post?
  9. #38
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    For the archives I believe those cold shifting problems are a bad seal in the trans. The OP probably junked the car by now.
  10. Remove Advertisements
