Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: 98 Deville Level Ride Questions; Problems
Old 07-04-09, 03:45 PM
brianroark's Avatar
Cadillac(s): 1998 Deville, one in pic is my old one.
View brianroark's Photo Album
Casino Cash: $895
Ok, I know there is a ton of literature around but I have been sifting through it and have not found a straight forward answer to my question.
The rear end of the car wasn't absorbing bumps like it should, It does now but, still leaks air and sometimes gives me a rough ride. I recently bought two arnott shocks and upon installing the shocks and pulling hte air line they released air.
Now the problem is though, I have a really slow leak, Most of the time That I park the Car after a couple of hours the air ride system will release the built up pressure and the air pump works almost everytime I go to start the car in the morning. I know this could be the lines, i think I've read about the air dryer and something else but I would feel a lot more comforitable if you guys could help me out on my situation specifically, If I have to pull the air pump so be it I have 4 6-Ton Jack Stands and a 4x4 block of wood.
Where Should I start and What should I Do? Also My pump has probably been running 85% more than the average persons pump for about a year so is there anything I should do to maybe rebuilt, lube, change oil or anything to freshen it up. Ive read something about getting a new air dryer.
Thanks much,
Brian
  #2 (permalink)
Old 07-04-09, 03:51 PM
Cadillac(s): 1998 Deville, (2) 2001 Devilles
View bigtone's Photo Album
Casino Cash: $7545
Re: 98 Deville Level Ride Questions; Problems
The air ride is something I really haven't had to work on (yet) on my 98 Deville, but I do know that my compresser kicks on every time the car is started, I thought I read where that is normal.[/i]
  #3 (permalink)
Old 07-04-09, 04:16 PM
dkozloski's Avatar
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $20332
Try posting your problem in a forum other than for Northstar Engines. Level ride is on the other end of the car.
Don't mess with Binky Bear!
  #4 (permalink)
Old 07-04-09, 04:51 PM
submariner409's Avatar
Casino Cash: $20694
You need to either have a Moderator move this to Cadillac Technical Discussion, Suspension, or hazard the possibility of posting a new thread down there. The level ride compressor sequencing is discussed at great length there.
  #5 (permalink)
Old 07-04-09, 05:47 PM
View Ranger's Photo Album
Casino Cash: $24241
Get the back end up on ramps. Get the compressor to run and then spray all the fittings with soapy water. The leak point will start to foam.
deville, level, problems, questions, ride
